Tangerine linkage kit, or Seine shifter, or both? |
Tdskip |
Jan 14 2018, 09:01 AM
Just doing some planning on the shifter set up.
I have a side shifter already. Installing a Seine shifter on the 911 was one of the best things I ever did. Tangerine's shifter set up appears to be the gold standard. Would the best plan of attack be to go with the Tangerine set up and then see how I like it before popping for the Seine shifter? Does the Tangerine kit usually make a Seine set up unncessary? Thanks in advance for the help. |
Steve |
Jan 14 2018, 10:57 AM
914 Guru Group: Members Posts: 5,596 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I started with a 915 shifter, added the seine kit, then switched to Wevo and ended up with rennshift.
Tdskip |
Jan 14 2018, 12:22 PM
Steve |
Jan 14 2018, 05:42 PM
I started with a 915 shifter, added the seine kit, then switched to Wevo and ended up with rennshift. Well I bet that was all fun.... Yep, I through away a lot of money. Made a lot of people happy with my second hand mistakes. The Martin Bott 915/916 kit requires a very precise shifting linkage. The rennshift left to right has a shorter throw than the others do, which made up for my sloppy linkage. I finally figured out the linkage, so the other shifters probably would of worked. I still think the rennshift is the best. The Seine kit and the wevo are based off of the 915 shifter. Pro and con, but i like the rennshift best. |
Lo-Fi Version | Time is now: 24th May 2024 - 06:25 AM |
