wheel sizes... will 16x8 work with flares? |
holtby914 |
Jan 14 2018, 02:42 PM
Newbie Group: Members Posts: 42 Joined: 16-November 16 From: Ontario, Canada Member No.: 20,593 Region Association: Canada |
Trying to figure out what is the biggest wheels that will fit with gt flares... anyone have some advice? I found some decently priced generic steal wheels from diamond wheels that are 16X8(-12 offset). Can they be made to fit?
914 Ranch |
Jan 14 2018, 04:07 PM
Team Sharp where the 914 grow wings Group: Members Posts: 1,396 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
What is a -12 offset? I run 8 16 Panasports with 225's and Boxster Snowflakes 8 16's with 225's but they don't fill up the wheel well like the Panasports.
holtby914 |
Jan 14 2018, 04:12 PM
Here is a wheel offset diagram:
https://www.google.ca/search?q=wheel+offset...Xt4bOO5KC4-hIM: Your car has flares I'm guessing? |
GeorgeRud |
Jan 14 2018, 05:08 PM
I know my 914-6 conversion car with GT flares has plenty of space up front running 15x7” Fuchs ( I don’t have access to their ET right now), so I think 8” should not be an issue as long as your tire size keeps a similar outer diameter. I have seen photos of 17” Ruf wheels fitted to aflated car, so 16” shouldn’t be an issue.
If possible, post pics of the wheels you’re planning to use. |
Mark Henry |
Jan 14 2018, 06:04 PM
If you have the right offset you can run 8" all around, but IIRC some use 7" on the front for street because it tracks better.
holtby914 |
Jan 14 2018, 06:17 PM
Thanks for advice. The wheels I was looking at are just generic steally's from diamond racing:
http://www.diamondracingwheels.com/index.p...o-street-wheels |
Mueller |
Jan 14 2018, 06:27 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311
^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. |
echocanyons |
Jan 14 2018, 06:29 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
You will need a spacer in the rear with 16 x 8 951 Fuchs
Attached thumbnail(s) |
IronHillRestorations |
Jan 14 2018, 07:06 PM
I've seen 8 & 9 x 16"s on a 914 widebody. The 8's were 944's
holtby914 |
Jan 14 2018, 07:42 PM
That site is great. Thanks!
gothspeed |
Jan 14 2018, 08:05 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I've seen 8 & 9 x 16"s on a 914 widebody. The 8's were 944's That would be awesome!!! If that setup fits with gt flares, I will try and go that route! (IMG:style_emoticons/default/w00t.gif) You will need a spacer in the rear with 16 x 8 951 Fuchs |
holtby914 |
Jan 14 2018, 08:09 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? |
echocanyons |
Jan 14 2018, 08:16 PM
Mine are a stock 944 spacer 23mm if I recall correctly.
They can be had for cheap. |
Mueller |
Jan 14 2018, 08:30 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? Better brakes with 5 lug if you swap over to 911 front suspension. /4 front are solid rotor 911 front is vented and there are kits to put larger and lighter calipers. Besides being cheap why the Circle track heavy steel rims? Define "worth it" (IMG:style_emoticons/default/smile.gif) It's only money. |
gothspeed |
Mine are a stock 944 spacer 23mm if I recall correctly. They can be had for cheap. |
gothspeed |
Jan 14 2018, 08:33 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Those 951 8's on the front look too close to the flare .... is that how they fit without spacers? |
Mueller |
holtby914 |
Jan 14 2018, 08:38 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? Better brakes with 5 lug if you swap over to 911 front suspension. /4 front are solid rotor 911 front is vented and there are kits to put larger and lighter calipers. Besides being cheap why the Circle track heavy steel rims? Define "worth it" (IMG:style_emoticons/default/smile.gif) It's only money. Exactly because they are cost effective. I plan to upgrade again later on. I also feel as though I can beat on the steel wheels, and don't have to worry about them. They won't be pretty but they will be functional. |
holtby914 |
Jan 14 2018, 08:41 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? Better brakes with 5 lug if you swap over to 911 front suspension. /4 front are solid rotor 911 front is vented and there are kits to put larger and lighter calipers. Besides being cheap why the Circle track heavy steel rims? Define "worth it" (IMG:style_emoticons/default/smile.gif) It's only money. I can always upgrade the wheels while doing the brakes and hubs, in the future. I have brand new refurbished brakes that I put on the car, they will work for now. |
holtby914 |
Jan 14 2018, 08:43 PM
Mine are a stock 944 spacer 23mm if I recall correctly. They can be had for cheap. Which for the OP, that would make them have a 0 effective offset (or close enough to it) , his wheels would stick out towards the outside of the car 15mm more. I found a guy running 8x16's (-64rear,-34front), and he says he could fit a much bigger tire if he wanted to. |
Lo-Fi Version | Time is now: 23rd April 2024 - 04:07 AM |
