how do my jugs look ?, pulled tin to check heads, found some dirt, oil |
DRPHIL914 |
Jan 14 2018, 07:28 PM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
75, 2.0. 150,000 miles
im the 4th owner, 8 years and this is the first time i have pulled tin. good compression and leak down 2 years ago, i am wondering if this oild and dirt is enough to pull heads? it was runnimg good and temps were great with aux. oil cooler- Attached thumbnail(s) |
DRPHIL914 |
Jan 14 2018, 07:29 PM
drivers side on these first 2
DRPHIL914 |
Jan 14 2018, 07:30 PM
Passenger side
DRPHIL914 |
Jan 14 2018, 07:33 PM
one more
DRPHIL914 |
Jan 14 2018, 07:43 PM
no known history of previous rebuild.
i have some records from previous owners but no documented work on the motor. |
thelogo |
Jan 15 2018, 02:16 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Since im very curious about circa 70s maintenance intervals
How often should you throw your jugs away and replace Every 100k miles? I know this is not popular here or cost effective But isn't this engine more power egg type design As in swap out the whole engine and go opposed to fix 1 thing at a time? |
McMark |
Jan 15 2018, 04:58 PM
Slippery slope. Pandora's box. If it ain't broke, don't fix it. Pick your favorite saying. (IMG:style_emoticons/default/wink.gif)
Mueller |
Jan 15 2018, 05:05 PM
You could just clean it up as good as possible, put it back into service and inspect again in the future.
Jan 15 2018, 05:15 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Unless you are itching to spend a couple grand, just clean up the grime and run it. It wont save you any money tearing it down now vs later.
DRPHIL914 |
Jan 15 2018, 06:59 PM
thats kind of what i figured. i dont think its major leak ir anything like that. i just wanted tk make sure. i dont want to dive in that deep now, maybe in a few years but i really wnat to just clean it up, install the new tin, runners, trottle body, plenum, seals etc etc- all newly powder coated heat parts coming from Bruce Stone! just cleaning and degreasing so that the motor will look as nice as the newly painted body! i think i probably have 2 months before paint gets done so i have some time to clean and reassemble. it is turning into " while i am at it" syndrome!
Mark, hopefully you and i both get our cars done for the next Okteenerfest! |
Lo-Fi Version | Time is now: 19th April 2024 - 07:05 PM |
