914-4 factory induction, Always FI? |
Jetsetsurfshop |
Jan 16 2018, 04:54 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I need help with a rule in the race series I've been running. (Champ car)
The way the rules are written means they hit me for 50pts each for my carbs. If any 914-4 were sold with carbs instead of FI I could make my case and use those points for other needed stuff (transmission cooler!!) |
Jetsetsurfshop |
Jan 17 2018, 09:10 AM
I thought all 914-4 were injected. This is awesome. I can try to use this to fight to get my 100pts back!! maybe at the worst they will only hit me for 50pts because my carbs are not single barrels.
Man guys thanks for the help. Champcar studies my car are because they are not so familiar with 914s. They mostly deal with BMWs and Miata's. Perry, My engine is not stock. Last dyno was 165rwhp. Running a stock appearance FI system would save 100pts and the ignition change would only cost me 20pts. I always like carbs. The system is so simple. I do have a spare stock engine with FI. I wonder if anyone else made a performance FI out of the stock stuff? |
jd74914 |
Jan 17 2018, 01:14 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
My engine is not stock. Last dyno was 165rwhp. Running a stock appearance FI system would save 100pts and the ignition change would only cost me 20pts. I always like carbs. The system is so simple. I do have a spare stock engine with FI. I wonder if anyone else made a performance FI out of the stock stuff? Does that mean you could get the full 100 pts back if you put a Megasquirt ECU in the stock brain box so it looked OEM-ish (you'd want a newer TPS, MAP, etc.) but used all modern components? |
Jetsetsurfshop |
Jan 17 2018, 01:54 PM
My engine is not stock. Last dyno was 165rwhp. Running a stock appearance FI system would save 100pts and the ignition change would only cost me 20pts. I always like carbs. The system is so simple. I do have a spare stock engine with FI. I wonder if anyone else made a performance FI out of the stock stuff? Does that mean you could get the full 100 pts back if you put a Megasquirt ECU in the stock brain box so it looked OEM-ish (you'd want a newer TPS, MAP, etc.) but used all modern components? I think so. Losing 100pts to carbs is a ton. My goal is to keep them and somehow squeeze room for that transmission cooler. I have an email to the director about letting me get some points back. Waiting to hear back now. I will look up that megasquirt thread. I honestly never considered switching. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:48 AM |
