Late model window regulator in an early door, I converted a 1972 door to use the scissor type window regulator. |
914Subaru |
Jan 16 2018, 08:29 PM
Member Group: Members Posts: 59 Joined: 19-October 08 From: Duluth, MN Member No.: 9,667 Region Association: Upper MidWest |
Not pretty but it works. Definitely need a 73 or later donor door with a lot of trial and error to get it tol work.
1970-72 is a lighter door because it doesn’t have the side impact reinforcement. Attached thumbnail(s) Attached image(s) |
GaroldShaffer |
Jan 16 2018, 08:58 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
There are early 73 model year cars with the early door and late style window lifts in them from the factory. Not sure I have anymore of those type doors in my stash, but I can check later in the week once we get done being dumped on by lake effect snow. (IMG:style_emoticons/default/mad.gif)
MarkV |
Jan 16 2018, 09:40 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I have an early 73 with no impact beams. I bought a set of later doors with beams with the intention of changing them when I paint the car. You could get seriously killed if you got t-boned in an early 914 ..... those doors don't weigh anything. (IMG:style_emoticons/default/smash.gif) |
Mikey914 |
Jan 16 2018, 10:44 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You will need the fuzzies that go in the front and rear tracks if you go from early to late. I know a guy that has them new (IMG:style_emoticons/default/biggrin.gif)
Aidan |
Jan 17 2018, 01:40 AM
Newbie Group: Members Posts: 18 Joined: 26-December 17 From: FWB Member No.: 21,729 Region Association: None |
I have an early 73 with no impact beams. I bought a set of later doors with beams with the intention of changing them when I paint the car. You could get seriously killed if you got t-boned in an early 914 ..... those doors don't weigh anything. (IMG:style_emoticons/default/smash.gif) Better than a motorcycle....lol |
rick 918-S |
Jan 17 2018, 05:28 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Did you finish both doors? I thought I had a set of early doors here or were the regulators missing... (IMG:style_emoticons/default/idea.gif) . Maybe save some work on the passenger side. Ready for spring? (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif)
914Subaru |
Jan 17 2018, 07:15 AM
Did you finish both doors? I thought I had a set of early doors here or were the regulators missing... (IMG:style_emoticons/default/idea.gif) . Maybe save some work on the passenger side. Ready for spring? (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) The passenger door is done except I need the lower guide track that bolts in with 2 bolts and one rear vertical felt glass guide. I say this every year, "this could be the year". It is looking good, the only project in the garage is the 914. I drove it up and down the road in front of the house last fall so it's getting close. |
914Subaru |
Jan 17 2018, 07:24 AM
There are early 73 model year cars with the early door and late style window lifts in them from the factory. Not sure I have anymore of those type doors in my stash, but I can check later in the week once we get done being dumped on by lake effect snow. (IMG:style_emoticons/default/mad.gif) Interesting I didn't know there was an interim design. |
Olympic 914 |
Jan 17 2018, 08:23 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
There are early 73 model year cars with the early door and late style window lifts in them from the factory. Not sure I have anymore of those type doors in my stash, but I can check later in the week once we get done being dumped on by lake effect snow. (IMG:style_emoticons/default/mad.gif) Interesting I didn't know there was an interim design. The US requirement for adding the door beams began with cars built in '73 (maybe US only?) So 1973 model year cars built from 9/72 thru 12/72 did not have the door beams but did have the later windows and regulators. My car is a 9-72 build. Its seems the only difference would be the inner panel that holds the window regulators. It looks like the factory used the same outer door skins from the early doors and the late inner panels on the 9/72 - 12/72 then in 1/73 added the door beams to the outer skins. Somewhere in here the roof changed also, I think I have late roof. |
roblav1 |
May 28 2020, 10:20 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I did a similar mod on my late 73. I used older doors and made 5 cut/slices to completely remove the old winding mechanisms structure and tigd in the new style structure.
horizontally-opposed |
May 28 2020, 10:37 AM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
There are early 73 model year cars with the early door and late style window lifts in them from the factory. Not sure I have anymore of those type doors in my stash, but I can check later in the week once we get done being dumped on by lake effect snow. (IMG:style_emoticons/default/mad.gif) Interesting I didn't know there was an interim design. The US requirement for adding the door beams began with cars built in '73 (maybe US only?) So 1973 model year cars built from 9/72 thru 12/72 did not have the door beams but did have the later windows and regulators. My car is a 9-72 build. Its seems the only difference would be the inner panel that holds the window regulators. It looks like the factory used the same outer door skins from the early doors and the late inner panels on the 9/72 - 12/72 then in 1/73 added the door beams to the outer skins. Somewhere in here the roof changed also, I think I have late roof. Another super early 1973 914 here. 193rd chassis number for that year. Has early regulators, and I'd love to move to the later setup. Just seems better in every way? Need to look at my doors next time they're apart. Now wonder if they'll accept either setup. (IMG:style_emoticons/default/idea.gif) My gut is no, as I bought a set of late doors years ago to harvest the parts but then got cold feet and sold those doors. And yes on the top—late top is different and I think everything has to match. Ah, that might be why I stayed with the early stuff: I found a NOS early top. |
Lo-Fi Version | Time is now: 5th May 2024 - 06:49 AM |
