914-6 Oil line fittings, What Degree fitting where? |
Kerrys914 |
May 31 2005, 08:18 AM
I have AN-12 fittings at the four connection points for the two hoses.
What degree fittings are needed at each connection? I am going to buy the fittings and hose to make my own hoses. I will need to test fit the engine to get the correct length of each hose. IIRC - 0 Deg for the lower tank - 45 Deg for the Upper tank - 90 For the engine block - 45 Deg for the oil cooler (I have a AN-12 90 Deg welded to the OEM cooler) Cheers and any sources for the above would be cool too (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:42 PM |
