Timing degrees and results and cautions...., Is 27 degrees it or can you deviate? |
second wind |
Jan 21 2018, 02:46 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there......my car just got back on the road due to a bad coil and it was tricky to find as it still sparked the plugs....just not under compression. During wrenching we altered the timing and it is at 33 degrees btdc now. Car starts great and has tons of low end.....kind of stops pulling at 5,000 rpm with slight knocking. Replaced seemingly healthy vacuum lines to distributor and high end improved a bit and some knocking sound lessened. What are your experiences with not being at 27 degrees and what are the risks? Thank you very much. BTW.....not driving car for months is depressing and now driving is really a blast!! No wonder we are here.
gg |
brant |
Jan 23 2018, 10:12 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
you can get away with higher timing numbers at altitude.
however you look to be in California... I'm assuming sea level? you really need to accurately time that car and getting closer to 27-29 is a really good idea or race gas at 10$/gallon |
Lo-Fi Version | Time is now: 27th May 2024 - 05:15 AM |
