Timing degrees and results and cautions...., Is 27 degrees it or can you deviate? |
second wind |
Jan 21 2018, 02:46 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there......my car just got back on the road due to a bad coil and it was tricky to find as it still sparked the plugs....just not under compression. During wrenching we altered the timing and it is at 33 degrees btdc now. Car starts great and has tons of low end.....kind of stops pulling at 5,000 rpm with slight knocking. Replaced seemingly healthy vacuum lines to distributor and high end improved a bit and some knocking sound lessened. What are your experiences with not being at 27 degrees and what are the risks? Thank you very much. BTW.....not driving car for months is depressing and now driving is really a blast!! No wonder we are here.
gg |
Rand |
Jan 23 2018, 06:47 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Monitor your temps if you are going to play with timing. Get a head temp gauge if you don't have one. Advanced timing raises head temps. Retarded timing raises oil temps. If any of your temps are pushing their range, something needs attention.
Lo-Fi Version | Time is now: 26th May 2024 - 09:18 PM |
