Bilstein VS Koni |
Bilstein VS Koni |
Justinp71 |
Jan 22 2018, 07:24 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I'm currently running Bilstein front inserts in my Boge T Struts, that may have been valved for my 914 but I don't know for sure as they were installed by the PO. In efforts to get better brakes I am putting in some Koni 3.5" Struts. Has anyone here compared the two in there car? What should I expect going from Bilstein's to Koni Yellow's?
AnthonyM |
Jan 22 2018, 08:53 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
Both inserts are a great choice either way. The Bilstein's are mono tube inserts with no adjustment/tuning and the Koni's are twin tube with rebound adjustment (weight transfer). I used to be in the Motorsports department with Koni and like the ability to tune the car for different set ups and tracks. I would not mix the two technologies together.
ablesnead |
Jan 22 2018, 09:18 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
Sometimes , shock ajustability is a gimmick looking for a need...I am sure there are plenty of people that go thru the adjustment motions with their shocks...I envy their sensitive shock dyno like butts.. I can only tell a general improvement when they are valved to my car weight and springs..the ability to stay that way for a while seems to lean toward Bilstein...and revalve and rebuilds are relatively cheap...most don't have properly valved shocks , just something close....adjusting improper valved ones is akin to polishing a turd...I vote bilstein with my wallet
Justinp71 |
Jan 23 2018, 05:06 PM
Thanks. I already have the new 3.5" Koni Struts in hand, I am mostly curious if the driving dynamics will change much between the two. The Koni struts have red inserts which I'll probably set to medium and run for now.
PlaysWithCars |
Jan 25 2018, 11:24 PM
Senior Member Group: Members Posts: 523 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I've found the Koni's to be stiffer than Bilsteins in general. When running in the stock class with our local PCA group, I liked using the Konis because I could crank up the rebound and it would simulate stiffer roll bars during the quick transitions of an autocross. In the longer turn arounds the car would still roll, but in slaloms they reduced the roll.
Now I've moved up to GT class and am actually using stiffer springs and bars so I'm back to the Bilsteins which seem to control the wheel ends better. |
Joe Ricard |
Jan 30 2018, 11:22 AM
Back in the day I had some shortened strut tubes (2.5") with some better race valves koni inserts. Had more wheel travel before bump stops. Only adjusting I did was front push = soften shock.
Justinp71 |
Jan 30 2018, 06:39 PM
Thanks guys. One thing I can't figure out is why the PO installed 220lb rear springs and left stock torsion bars up front (17.9mm). With the Bilstein pressurized shocks and a 19mm sway bar it doesn't feel that soft in the front... but seems a little mis-matched. I've been running it this way for 10 years. Once I went from 205's to 225's in the rear it seems to be well balanced enough for a street car. Probably would handle better with 19 or 20mm front bars.
I just want a well handling street machine that I can take to the track or A/X on occasion. |
infraredcalvin |
Jan 31 2018, 12:57 AM
Distracted Member Group: Members Posts: 1,506 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
What exactly are you trying to achieve? Sounds like the issue is the perceived mismatch in your head, not necessarily a problem with handling.
Appears that the PO was looking to get some push out of the car by putting the stiffer springs in the back. Probably could have done the same by installing a rear sway instead of the stiffer springs. Regardless, identify the real problem (if any) and work on tuning it out. Don’t just throw parts at it because it doesn’t seem right... Ask around the track, drive another or drive in another car, see if there is really something to gain. |
yeahmag |
Feb 6 2018, 04:59 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
It's the other way round... Stiffer = less grip (relative to the softer end).
Justinp71 |
Feb 6 2018, 06:37 PM
What exactly are you trying to achieve? Sounds like the issue is the perceived mismatch in your head, not necessarily a problem with handling. Appears that the PO was looking to get some push out of the car by putting the stiffer springs in the back. Probably could have done the same by installing a rear sway instead of the stiffer springs. Regardless, identify the real problem (if any) and work on tuning it out. Don’t just throw parts at it because it doesn’t seem right... Ask around the track, drive another or drive in another car, see if there is really something to gain. Well I read a couple articles stating your shocks should match your torsion bars. I appear to have stiffer shocks and softer torsion bars in the front. Typically in autocross I have over steer. However when the back end gets loose its controllable and predicable. I believe my car would handle a little better with 19 or 20mm front torsion bars. Funny when I think back to when I ran 205's rear tires and 220lbs rear springs it could spin out really fast, I was 180 before I could blink. Now with 225 rear tires and 200lb springs it's much more predictable. I also have 3.2 motor (had a 2.7L before) |
naro914 |
Feb 11 2018, 08:15 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Our autocross/hillclimb/street/fun/ whatever car Huey has Koni adjustables around, 225 lb springs, 21mm torsion bars, and whatever Weltmeisters big front roll bar is, no rear roll bar. 3.2 engine, 245/16 tires around. Car handles PERFECT. Autocross, hillclimb, and through the mountains, it’s predictable and confidence inspiring. Around town it’s definitely stiff, but not harsh at all. I wouldn’t change a thing.
Justinp71 |
Feb 12 2018, 10:59 AM
Our autocross/hillclimb/street/fun/ whatever car Huey has Koni adjustables around, 225 lb springs, 21mm torsion bars, and whatever Weltmeisters big front roll bar is, no rear roll bar. 3.2 engine, 245/16 tires around. Car handles PERFECT. Autocross, hillclimb, and through the mountains, it’s predictable and confidence inspiring. Around town it’s definitely stiff, but not harsh at all. I wouldn’t change a thing. Thanks for sharing! Are the Koni's factory valving? Do you play with the rebound adjustment with different tracks? I have heard leaving the rebound on soft works well. |
naro914 |
Feb 12 2018, 11:20 AM
They are as from the factory.
I do stiffen them up for the track, soften for hillclimb and street and honestly have no idea where they need to be for autocross since we've only had them on for one autocross and i played with them each run. Need more time with them there... |
slivel |
Feb 12 2018, 01:31 PM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
I have been using Bilstein shocks for years on my track only car. I am fortunate to have a major Bilstein facility near where I live. I provided data to the shock engineer to custom valve my shocks. I provided information like: spring rates, sway bar size, corner weights, tire and wheel size, type driving (track only). Custom valving was reasonable in price (less than $100/shock) and turnaround time also reasonable.
Because the shocks are not adjustable, I probably don't have the ultimate in performance gain, but I can live with it because they are install and go race. Don't need a shock expert with me at the track to do constant tuning. Here is what they did for me. The graphic shows before and after settings and what they did to low, medium and high speed settings. My spring rates are 450 front and 400 rear. Coil over front not torsion bar. |
sixnotfour |
Feb 22 2018, 10:39 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
koni yellow stiff
Koni reds softer NLA Koni hydraulic reds the original NLA do you have red hydraulics or gas ?? |
infraredcalvin |
Feb 23 2018, 12:07 AM
infraredcalvin |
Feb 23 2018, 12:15 AM
Well I read a couple articles stating your shocks should match your torsion bars. I appear to have stiffer shocks and softer torsion bars in the front. Typically in autocross I have over steer. However when the back end gets loose its controllable and predicable. I believe my car would handle a little better with 19 or 20mm front torsion bars. Funny when I think back to when I ran 205's rear tires and 220lbs rear springs it could spin out really fast, I was 180 before I could blink. Now with 225 rear tires and 200lb springs it's much more predictable. I also have 3.2 motor (had a 2.7L before) A quick test would be to adjust your front sway stiffer (if you can) and see how it responds. If it handles closer to your optimum, get the larger torsions, but loosen up the sway again. Your sway should be set that you can fine tune the handling dependent on course or conditions. |
Justinp71 |
Feb 27 2018, 12:17 PM
koni yellow stiff Koni reds softer NLA Koni hydraulic reds the original NLA do you have red hydraulics or gas ?? I know you can get the Koni reds for a Koni strut, I think you can still get them for a Boge? The struts came with hydraulic Koni reds. They are original, seem to function ok. But when I compare them to my Bilsteins by a hand push, they are waaaay softer. The Koni struts ended up having a bad deformation on the top by the gland nut for some reason, so I sent them back to the seller. I am now going with Boge struts and I can use either insert. I think I will look for some Koni Red gas inserts to try. |
stownsen914 |
Feb 28 2018, 09:02 AM
Senior Member Group: Members Posts: 912 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
You should be able to get Konis for Boge struts - that's what I have. The newer gas shocks are better than the older hydraulics, but you may be able to find someone to rebuild and possibly revalve your hydraulics if you are wanting to keep those. Probably almost as much to do that as to just buy new ones though.
Scott |
Justinp71 |
Feb 28 2018, 12:27 PM
Our autocross/hillclimb/street/fun/ whatever car Huey has Koni adjustables around, 225 lb springs, 21mm torsion bars, and whatever Weltmeisters big front roll bar is, no rear roll bar. 3.2 engine, 245/16 tires around. Car handles PERFECT. Autocross, hillclimb, and through the mountains, it’s predictable and confidence inspiring. Around town it’s definitely stiff, but not harsh at all. I wouldn’t change a thing. This is great to hear. What are you running for a- arm bushings? I hear that can make a difference too. And are you running Koni reds or yellows? |
Lo-Fi Version | Time is now: 24th April 2024 - 12:08 PM |
