Oil Temperature Sending Unit, 12mm or 14mm? |
tracks914 |
May 31 2005, 03:22 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I just recieved my new oil temp sending unit from Mid America Motorworks. I drained the oil and went to install the sending unit but the threads were to big. It appears my oil drain plug is a 12mm and the sending unit is a 14mm.
Anyone else ever come across this? Tx |
Cap'n Krusty |
May 31 2005, 03:29 PM
It doesn't screw into the drain plug hole, it goes in a special replacement cover for the hole on the left side of the pan, the one held in by 2 6mm bolts. The Cap'n
machina |
May 31 2005, 03:35 PM
you need this part, called a taco plate. Takes your 14mm probe.
tat2dphreak |
May 31 2005, 03:39 PM
ahh... more probe problems... this one's trying to put his probe in the wrong hole, and it's too big!
(IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) maybe you just need a better oil to make it fit... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) they are right though... you gotta put it in the taco |
tracks914 |
May 31 2005, 06:57 PM
OK then, where do I get a good Taco?
Just in case anyone answers Mexico I 'll beat you to it. Tx |
mike_the_man |
May 31 2005, 07:09 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
It should already be there. As far as I know, all cars came with the sender, just not the gauge. Crawl under and have a look. It's on the drivers side of the engine case, towards the front of the car. 2 10mm bolts hold it on, I believe.
tat2dphreak |
May 31 2005, 08:31 PM
negative, not all cars came with a taco plate, and his car is a '72... NONE came with them until '73... if they didn't have an oil gauge, they didn't have the sender and thuse didn't have a taco... they just had a flat plate there... that flat plate can be tapped and drilled to hold the sender though... |
tracks914 |
Jun 1 2005, 07:42 PM
OK but somebody must have an old one lying around. Didn't all of them after '73 come with them? There must be an old 1.8 scrapped out there somewhere. Jake maybe?
tat2dphreak |
Jun 2 2005, 03:48 PM
2.0s came with them, 1.8s with the option.... there are taco plates available every now and then though... try Fred Vollermerson(vollme914 on pelican) |
mike_the_man |
Jun 2 2005, 06:09 PM
Sorry for the misinformation! I guess I don't know everything about 914s! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Wait, 'I guess I don't know anything about 914s' That should be more accurate. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
tat2dphreak |
Jun 2 2005, 08:11 PM
If someone gave me a dollar every time I was wrong and gave bad info, and I, in turn, gave a dollar to someone everytime I actually knew something... my car would be done, and I would have converted to a 3.2 6 and still had plenty of money left... I'm wrong so often there should be a buzzer when I post... usually IF I get info right, is because I've asked the question before, usually twice... such was the case with this... (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
ajracer |
Jun 3 2005, 06:00 AM
Member Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
Greetings Doug:
Try our friend Mike Galloway @ Mike's 914 he should be able to help you out reasonably; in case you need other parts ask him. Then just get him to ship up to Timmins by parcel post. Tel# (905) 355-2703 or cell# (905) 922-8987 Allan Mayhew PS Is all you snow gone yet ? PPS Are you still looking or interested in side shifter tranny ? |
Mueller |
Jun 3 2005, 10:58 AM
i'm attempting to learn BobCAD/CAM right now so that I can program my machine to make a few of these (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
another one of those vaporware projects, hahaha (IMG:http://www.914world.com/bbs2/uploads/post-2-1065156783.jpg) |
tracks914 |
Jun 3 2005, 02:47 PM
Looks nice but I want mine in yellow. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) How much would you be selling them for? Tx |
Mueller |
Jun 3 2005, 03:03 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 04:00 PM |
