Heating |
Heating |
moost |
Jan 27 2018, 07:19 PM
Newbie Group: Members Posts: 26 Joined: 6-January 18 From: seattle wa Member No.: 21,762 Region Association: Pacific Northwest |
Everything works in my car except the heating. All 3 functions work on the dash and air comes out the dash and vents. Heat exchanger, tin and hoses all look good. The only thing i can see so far is the missing heat lever and cable that attaches to the valve. Is there anyway to bypass the lever and keep the heat on permanently? Would it be as easy as keeping the valve opened? What is the wire that connects to the lever for?
Jan 27 2018, 07:23 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The wire turns on the heater blower in the engine bay, if you have one.
I guess you could keep the valves open manually, they're spring loaded, so you'll have to find a way to keep the arms extended. (IMG:style_emoticons/default/idea.gif) |
moost |
Jan 27 2018, 07:33 PM
The wire turns on the heater blower in the engine bay, if you have one. I guess you could keep the valves open manually, they're spring loaded, so you'll have to find a way to keep the arms extended. (IMG:style_emoticons/default/idea.gif) Ahhh okay. I do not have the heat blower then. I was wondering how the heat would transfer through the cabin up into the dash (IMG:style_emoticons/default/laugh.gif) Thanks |
bbrock |
Jan 27 2018, 07:54 PM
You still get a lot of heat without the blower. The engine fan blows heat to the dash. The blower only comes on when the heat lever is pulled all the way up. If it were me, I'd get a heat lever and cable as they are not expensive. You could worry about the blower later. I think if you just wire the flapper valves open, you will cook yourself. The system produces a surprising amount of heat.
Jan 27 2018, 08:30 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You still get a lot of heat without the blower. The engine fan blows heat to the dash. The blower only comes on when the heat lever is pulled all the way up. If it were me, I'd get a heat lever and cable as they are not expensive. You could worry about the blower later. I think if you just wire the flapper valves open, you will cook yourself. The system produces a surprising amount of heat. (IMG:style_emoticons/default/agree.gif) with everything above. The stock heating system, even without the blower (I don’t have one) will cook you in the cabin. Just get a used lever-$25 and a cable from 914rubber ~$35 and you should be set. You will love a good working system. |
jim_hoyland |
Jan 27 2018, 08:46 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) And, if you don’t feel the heat after running 5 minutes, crack the driver side window about 3 inches. It will “pull” the hot air up into the cabin. I gradually close the window as it heats up.... (IMG:style_emoticons/default/smile.gif)
Spoke |
Jan 27 2018, 09:27 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So you have confirmed all the plumbing to and from the heat exchangers including:
o Pipes from the fan shroud to the HEs o Pipes/hoses/flapper valve from the HEs to the pipes that go to the cabin. If all is there, but the guide wire from the handle in the cabin is missing, for a quick fix to get heat just wire the flapper valves to be open. Pull the lever on the flapper and wire it to anything solid under the engine. Having the valves open full time is ok since there's not a lot of heat coming off the HEs in real cold weather. Some pics of the plumbing under the car to/from the HEs would be helpful. |
moost |
Jan 28 2018, 02:53 AM
You still get a lot of heat without the blower. The engine fan blows heat to the dash. The blower only comes on when the heat lever is pulled all the way up. If it were me, I'd get a heat lever and cable as they are not expensive. You could worry about the blower later. I think if you just wire the flapper valves open, you will cook yourself. The system produces a surprising amount of heat. (IMG:style_emoticons/default/agree.gif) with everything above. The stock heating system, even without the blower (I don’t have one) will cook you in the cabin. Just get a used lever-$25 and a cable from 914rubber ~$35 and you should be set. You will love a good working system. Any heat will help at this point. I'm mostly concerned about my defrost not working. My windows tend to fog up since I usually have a lot of condensation in the cabin. I'll try to wire the flapper valves open and see if i get any heat. (IMG:style_emoticons/default/agree.gif) And, if you don’t feel the heat after running 5 minutes, crack the driver side window about 3 inches. It will “pull” the hot air up into the cabin. I gradually close the window as it heats up.... (IMG:style_emoticons/default/smile.gif) So you have confirmed all the plumbing to and from the heat exchangers including: o Pipes from the fan shroud to the HEs o Pipes/hoses/flapper valve from the HEs to the pipes that go to the cabin. If all is there, but the guide wire from the handle in the cabin is missing, for a quick fix to get heat just wire the flapper valves to be open. Pull the lever on the flapper and wire it to anything solid under the engine. Having the valves open full time is ok since there's not a lot of heat coming off the HEs in real cold weather. Some pics of the plumbing under the car to/from the HEs would be helpful. Any heat helps (IMG:style_emoticons/default/smile.gif) I'll try to do that tomorrow if I can figure out a way to get underneath my car... Will the heat come out of all 4 vents? |
bbrock |
Jan 28 2018, 10:19 AM
Any heat helps (IMG:style_emoticons/default/smile.gif) I'll try to do that tomorrow if I can figure out a way to get underneath my car... Will the heat come out of all 4 vents? Shouldn't be too hard to reach under to wire the flapper boxes open. The heat can still be directed to desired vents using the dash controls. You just won't get as much volume of air at full heat without the blower. Also, since your blower is missing, you'll want to make sure that the two j-pipes that run up through the engine shelf are both blocked off. Otherwise, most of the heat will get dumped into the engine bay. |
rhodyguy |
Jan 28 2018, 10:38 AM
For temp heat you can zip tie the flappers in the open position. Too hot? Mix cooler air with the dash heat controls. You also need to have caps on the J tubes or the hot air pours into the engine compartment.
98101 |
Jan 28 2018, 01:15 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 19th May 2024 - 01:45 AM |
