Headlight leaks |
Headlight leaks |
gulf908 |
Jan 28 2018, 04:05 AM
Member Group: Members Posts: 123 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
having some leaks into the headlights and thought I saw some tadpoles yesterday ....
I did a search here but I think I'm putting the wrong words in I found something in passing a long time ago that suggested the only longterm solution was to drill some small drainage hole/s but I can't find it again does anyone have some links for this subject - I assume I should address it sooner rather than later TIA Dennis (IMG:style_emoticons/default/smile.gif) |
Matty900 |
Jan 28 2018, 05:49 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I would just replace the headlight. It is not that expensive and will be an easy fix.
(IMG:style_emoticons/default/beerchug.gif) |
Spoke |
Jan 28 2018, 09:13 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
having some leaks into the headlights Are you referring to the sealed beam headlights? The actual light bulb? These shouldn't leak at all and if so, just replace them. In pairs of course in case there's a difference in light output or color temperature from the old lights. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:42 AM |
