Best Battery...., What is best for our cars? |
BuddyV |
Jan 31 2018, 12:39 AM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
The last battery I bought was an Optima...... that was about 7 years ago. What do you all think of the Optima..... and is there anything better?
Pros and Cons? New technology? Better value? I recall the Optima was much more expensive than other batteries. Cheers! (IMG:style_emoticons/default/beerchug.gif) |
Rand |
Jan 31 2018, 05:47 PM
Why anyone would still use an old school lead acid design under an engine grill that lets moisture on the battery these days is beyond me. I run Odyssey PC 680. Go sealed and never look back.
rgalla9146 |
Jan 31 2018, 06:52 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Why anyone would still use an old school lead acid design under an engine grill that lets moisture on the battery these days is beyond me. I run Odyssey PC 680. Go sealed and never look back. I just looked at the PC 680. It doesn't appear to have conventional posts. How have you attached the cables ? |
wndsrfr |
Jan 31 2018, 07:15 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Why anyone would still use an old school lead acid design under an engine grill that lets moisture on the battery these days is beyond me. I run Odyssey PC 680. Go sealed and never look back. I just looked at the PC 680. It doesn't appear to have conventional posts. How have you attached the cables ? The cables are attached with the SAE terminals that they sell for about $12--nice brass terminals that bolt down on top of the battery. Consider the PC925 which has about double the reserve power if you're not fanatical about weight. Another consideration is mounting...I've mounted the PC680 laying flat so the terminals are on the side--have to modify the hold down "J" bolts but no big deal. The PC925 mounts upright, more conventional but still needs shorter "J" bolts for the hold down (I just sawed off & bent the end of a generic FLAPS set). Note there's a PC925L with the terminals reversed--don't think you want that unless you've modified the cables. Battery Mart is a great supplier, & free shipping is a killer deal. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:32 PM |
