Reuse the engine compartment black noise insulating pads or are there better options? |
gothspeed |
Feb 1 2018, 02:47 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Mine are die cut. As far as water absorption goes - The idea is it will not hold water against the metal if it's not absorbed. The real issue becomes drainage and how much water is in the engine bay and why. With a 6 it's pretty obvious, but remember The problem is more a matter of continued exposure. I do make both rain trays. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) What is the thickness and weight of your pad pictured above? (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
Feb 1 2018, 06:23 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
68 oz with velcro. Nominal 5/8" uncompressed. Slightly thinner than OEM.
I just did the install. Went pretty easily. I'll be posting up another dreadded GB with the insatll tonight late. I have some shipping to help out with today. Mine was naked, but I will remove for Cary to patch the holes I have, Should easily go back in. I used enoough t hold it but didn't go crazy 20" of velcro. I can also include 24" strips with this. I think you will like |
Mikey914 |
Feb 2 2018, 03:41 AM
Attached thumbnail(s) |
Mikey914 |
Feb 2 2018, 03:44 AM
Crappy phone camera, I'll get better pics tomorrow. This on is ok to give you a better idea of how it looks.
bbrock |
Feb 2 2018, 08:47 AM
Question: Do you make the NLA large plastic disc fastener (Part # 914 559 377 10) that helps fasten the pad to the firewall? Those usually break when removing the pad so it would be nice to have replacements.
dr914@autoatlanta.com |
Feb 2 2018, 09:02 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
You can get them at napa, almost identical to the factory original ones. Part number is 665-3116
Question: Do you make the NLA large plastic disc fastener (Part # 914 559 377 10) that helps fasten the pad to the firewall? Those usually break when removing the pad so it would be nice to have replacements. |
bbrock |
Feb 2 2018, 09:36 AM
You can get them at napa, almost identical to the factory original ones. Part number is 665-3116 (IMG:style_emoticons/default/thumb3d.gif) I knew they had an assortment of these but hadn't compared to see if any match. Thanks for the P/N! |
Mikey914 |
Feb 2 2018, 11:22 AM
Thanks,
I'll pick up a box or two and throw these in with the new pads. Mark |
Feb 4 2018, 03:54 PM
mb911 |
Feb 4 2018, 04:10 PM
914 Guru Group: Members Posts: 6,879 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am curious if one were to put something like dyna mat in the cabin would the engine compartment insulation be required?
Lo-Fi Version | Time is now: 6th June 2024 - 11:15 PM |
