Internal cavity rust treatment, Would/do you use Ospho? |
bbrock |
Feb 2 2018, 09:33 AM
This question is specifically for those enclosed cavities that do not get opened during a full rustoration. On my car, there aren't many (inner cavities of roof pillars, roll bar, windshield frame, trunk cross member, and inside driver's suspension console). I bought a bunch of tubing to modify a garden pump sprayer so I could spray Ospho/Jasco inside those cavities. My thinking is that it would seep into seams where there is ALWAYS rust even in parts in good condition, and convert whatever rust it contacts. This would be followed by treating with Eastwood Internal Frame Coating, and finally, 3M Cavity Wax Plus. So two questions about the Ospho treatment:
1. Would you do it? It makes sense in my head, but it is spraying acid inside structural components. 2. If you did, would you follow with a water spray to neutralize the acid? My understanding is that the product forms a protective coating that can be left indefinitely, but it needs to be neutralized before it can be painted. For internals, I wonder if I'd get better long-term protection by just spraying Ospho and leaving it alone. Thoughts? |
aggiezig |
Feb 2 2018, 03:06 PM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I've almost exclusively used Master Series in the past for spraying into cavities. It's less of a rust treatment more of a rust encapsulator / prevent it from growing or spreading. It's a 1K product, moisture cured. It can be thinned and sprayed out of a gun or brushed.
Here's their website: http://www.masterseriesct.com/ It's not cheap at $35-40 per quart, but I've had really good results. I also use it as a primer on top of metal that has been treated or had the rust removed. The entire bottom side of my 914 and some of the trunks or other panels have this as a primer, some places were even top-coated with epoxy on top of this stuff to really keep rust out. It's not as thick or as messy to work with as POR-15 and it won't peel and flake off if you don't apply it exactly as described. The problem with just using epoxy is that unless you've gotten every last bit of rust pores out of the metal, it will eventually come back. At least with this stuff, I'd like to believe it's truly encapsulated and sealed away. |
Lo-Fi Version | Time is now: 24th May 2024 - 12:58 AM |
