Internal cavity rust treatment, Would/do you use Ospho? |
bbrock |
Feb 2 2018, 09:33 AM
This question is specifically for those enclosed cavities that do not get opened during a full rustoration. On my car, there aren't many (inner cavities of roof pillars, roll bar, windshield frame, trunk cross member, and inside driver's suspension console). I bought a bunch of tubing to modify a garden pump sprayer so I could spray Ospho/Jasco inside those cavities. My thinking is that it would seep into seams where there is ALWAYS rust even in parts in good condition, and convert whatever rust it contacts. This would be followed by treating with Eastwood Internal Frame Coating, and finally, 3M Cavity Wax Plus. So two questions about the Ospho treatment:
1. Would you do it? It makes sense in my head, but it is spraying acid inside structural components. 2. If you did, would you follow with a water spray to neutralize the acid? My understanding is that the product forms a protective coating that can be left indefinitely, but it needs to be neutralized before it can be painted. For internals, I wonder if I'd get better long-term protection by just spraying Ospho and leaving it alone. Thoughts? |
euro911 |
Feb 25 2018, 12:00 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Milt Becker (Zeke) applied Ospho after patching the hell hole area in the 'BB' and told me to rinse with water and immediately blow the area dry with compressed air the following day. Next was primer and a couple days later the top coat.
I hit the tunnel with the Eastman Internal Frame Coating prior to installing the shift rod & lever, still want to coat the longs at some point. Being on the west coast (CA & AZ), I doubt I'll need anything else (like wax) in the cavities. |
Costa05 |
Feb 25 2018, 10:45 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Milt Becker (Zeke) applied Ospho after patching the hell hole area in the 'BB' and told me to rinse with water and immediately blow the area dry with compressed air the following day. Next was primer and a couple days later the top coat. I hit the tunnel with the Eastman Internal Frame Coating prior to installing the shift rod & lever, still want to coat the longs at some point. Being on the west coast (CA & AZ), I doubt I'll need anything else (like wax) in the cavities. I agree. But instead of Ospho I am using this Home Depot stuff which is really affordable. Brush it on or spray bottle even. Several coats over a couple hours. Wire brush where you can reach. Goes black like rust converter. Rinse with water. Immediate compressed air to dry. Heat gun if you are concerned. Hit it with epoxy, acid etch prime, or Por 15 soon. Works for me anyways. Rich Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:12 AM |
