G lite, Not going off. |
malcolm2 |
Feb 3 2018, 02:38 PM
Took a 3 hour drive to Knoxville today. I watched the volt gauge. Seemed to be irratic. Hung at 11.4. But would jump to 13.5 for a short time them back to. 11.4. G lite was not on during the drive. After a short stop the re start is when the lite stayed on. Guage still at 11.4. I gotta get home.
Auto zone has a voltage reg. Is this a typical symptom of the easy to replace VR? |
mgphoto |
Feb 3 2018, 02:49 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I'm using the autozone vr , working ok.
You need to check the alternator, jumper wire to by pass the vr and measure voltage at the battery. Google search for the procedure. |
Spoke |
Feb 3 2018, 03:46 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm using the autozone vr , working ok. You need to check the alternator, jumper wire to by pass the vr and measure voltage at the battery. Google search for the procedure. (IMG:style_emoticons/default/agree.gif) The schematic for the 914 charging system is below. You can easily test the alternator by pulling the VR and shorting the D+ and DF leads in the VR connector. This will force the alternator to put out maximum power. The voltage at the battery should be 14-16V. If not, the alternator may be bad or the belt is loose. Keep in mind when doing this test that to get the alternator fully functional you may need to rev the engine to 2k or so. I too have an autozone VR in my 914. Works great. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 04:29 AM |
