G lite, Not going off. |
malcolm2 |
Feb 3 2018, 02:38 PM
Took a 3 hour drive to Knoxville today. I watched the volt gauge. Seemed to be irratic. Hung at 11.4. But would jump to 13.5 for a short time them back to. 11.4. G lite was not on during the drive. After a short stop the re start is when the lite stayed on. Guage still at 11.4. I gotta get home.
Auto zone has a voltage reg. Is this a typical symptom of the easy to replace VR? |
malcolm2 |
Feb 5 2018, 04:34 PM
Test results.:
EDIT>>>> ALT belt is installed and properly tensioned. VR pulled out Jumper in place of VR VOM on the battery 12.67v Key on G Lite on Car starts A few engine revs G Lite still on VOM = 12.13 idle and 3000 rpm Headlights, fresh air fan, hazzards,wipers all on VOM = 11.7 idle Bad ALT, right? |
worn |
Feb 5 2018, 05:17 PM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Test results.: VR pulled out Jumper in place of VR VOM on the battery 12.67v Key on G Lite on Car starts A few engine revs G Lite still on VOM = 12.13 idle and 3000 rpm Headlights, fresh air fan, hazzards,wipers all on VOM = 11.7 idle Bad ALT, right? I would say yes. Too bad, cause they aren’t fun to replace. Not horrible, but the tins make it harder than with most cars. |
Spoke |
Feb 5 2018, 05:22 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Test results.: VR pulled out Jumper in place of VR VOM on the battery 12.67v Key on G Lite on Car starts A few engine revs G Lite still on VOM = 12.13 idle and 3000 rpm Headlights, fresh air fan, hazzards,wipers all on VOM = 11.7 idle Bad ALT, right? I would say yes. Too bad, cause they aren’t fun to replace. Not horrible, but the tins make it harder than with most cars. (IMG:style_emoticons/default/agree.gif) In your test the only item in the charging system is the alternator. I assume you've checked the belt to make sure it's tight. Also sounds like you revved the engine a couple of times to get the alternator started. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:22 AM |
