WTB: good 944 axel with the 914 axel spline count |
tazz9924 |
Feb 3 2018, 07:13 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
As stated in the title i need a 944 axel or just the cv joints and boots (33 spline), im gonna use it to beef up the outer cv joints on my 914.
porschetub |
Feb 3 2018, 07:40 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
tazz9924 |
Feb 3 2018, 07:45 PM
As stated in the title i need a 944 axel or just the cv joints and boots (33 spline), im gonna use it to beef up the outer cv joints on my 914. Not sure why as the standard parts will handle it fine....944 axles are many ,late early,auto and manual. Not when you’re making 250whp lol. Idc about axel length just need the cv joints, and I figured theres more people with axels than solo cv joints |
tazz9924 |
Feb 5 2018, 07:59 PM
Bump (IMG:style_emoticons/default/icon_bump.gif)
914Sixer |
Feb 5 2018, 10:23 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All you need is 944 CV joints or go with VW Bus CV's. They are both 6 bolt 100mm 33 splines. The 944 CV has 23 % angle while the bus is at 17% degrees. Standard 914 is at 13 %. 944 axles are too short. You have to turn your 914 axles or go with aftermarket. You will need 911 stub or a modified 944 stub on the wheel side.
bdstone914 |
Feb 5 2018, 10:27 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Read Eric's thread on the use of 944 CV's.
Need to mod the 9114 axle shafts slightly. http://www.914world.com/bbs2/index.php?sho...p;hl=conversion |
tazz9924 |
Feb 6 2018, 12:15 PM
I know the axel won’t fit just using the cv joints.
tazz9924 |
Feb 6 2018, 12:16 PM
All you need is 944 CV joints or go with VW Bus CV's. They are both 6 bolt 100mm 33 splines. The 944 CV has 23 % angle while the bus is at 17% degrees. Standard 914 is at 13 %. 944 axles are too short. You have to turn your 914 axles or go with aftermarket. You will need 911 stub or a modified 944 stub on the wheel side. Ive got all that under control just need the cv joints to make it work (IMG:style_emoticons/default/biggrin.gif) |
tazz9924 |
Feb 8 2018, 01:23 PM
Bump still looking! (IMG:style_emoticons/default/icon_bump.gif)
Lo-Fi Version | Time is now: 28th April 2024 - 05:48 AM |
