WTB: good 944 axel with the 914 axel spline count |
tazz9924 |
Feb 3 2018, 07:13 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
As stated in the title i need a 944 axel or just the cv joints and boots (33 spline), im gonna use it to beef up the outer cv joints on my 914.
914Sixer |
Feb 5 2018, 10:23 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All you need is 944 CV joints or go with VW Bus CV's. They are both 6 bolt 100mm 33 splines. The 944 CV has 23 % angle while the bus is at 17% degrees. Standard 914 is at 13 %. 944 axles are too short. You have to turn your 914 axles or go with aftermarket. You will need 911 stub or a modified 944 stub on the wheel side.
Lo-Fi Version | Time is now: 9th May 2024 - 03:27 PM |
