Shift Rod Coil Pin Hole ? |
ChrisFoley |
Feb 9 2018, 12:25 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With the console removed you can move each selector rod into gear by levering with a big-ass screwdriver/prybar.
You can also verify that the spacing/alignment of the selector rods is correct if you have the specs from the workshop manual. |
Dr Evil |
Feb 9 2018, 01:17 PM
Those washers are missing on most of the shifter consoles and are not actually critical to the operation of the part. They serve to keep wear of metal on metal down to a minimum, but there is not all that much wear. The comb will align with the rods irrespective of the washers presence.
Yes, make sure no paper gasket is there (only the O ring). It is a tail shift/nose shift part and can mess up shifting with a side shift console. I also wonder if work was done recently and the rods were not adjusted correctly. Chris has the right next step, try shifting them with a screwdriver or bar from the hole. Sometimes it is a pain to shift into gear with it not running or if it hasn't been lubed by being run after someone was in it. The fact that you can shift once the Swepco is drained is odd. That would indicate that your synchro bands are not able to exert enough force on the slider to keep it locked in and it is too slick causing it to pop out. Like trying to hold a greasy pig. |
cary |
Feb 9 2018, 10:45 PM
I think Mike's owned the car 10 years. Daily driver in San Diego 5 years ago. Been on jack stands the 5 years its been in PDX. Who knows. Tried it with dyno gear lube. No go. (IMG:style_emoticons/default/dry.gif)
Swapping out the gear box from my project car. We have it about ready to drop on the table. Mike's thinking he'll take a swing it rebuilding. Now me I'm thinking I'll start begging for a Dr. Evil rebuild clinic here at MiddleMotors. Starting List : Cary Super In Law (Jack) Mark Whitesell Matt Whitesell Mike Warhurst Taylor Whitesell Maybe we can use the McMenamins Grand Lodge for our out of town guests. (IMG:style_emoticons/default/biggrin.gif) |
Dr Evil |
Feb 9 2018, 10:52 PM
I think Mike's owned the car 10 years. Daily driver in San Diego 5 years ago. Been on jack stands the 5 years its been in PDX. Who knows. Tried it with dyno gear lube. No go. (IMG:style_emoticons/default/dry.gif) Swapping out the gear box from my project car. We have it about ready to drop on the table. Mike's thinking he'll take a swing it rebuilding. Now me I'm thinking I'll start begging for a Dr. Evil rebuild clinic here at MiddleMotors. Starting List : Cary Super In Law (Jack) Mark Whitesell Matt Whitesell Mike Warhurst Taylor Whitesell Maybe we can use the McMenamins Grand Lodge for our out of town guests. (IMG:style_emoticons/default/biggrin.gif) I love McMenamins (IMG:style_emoticons/default/smile.gif) I’m closing down for a few weeks/mo. Right now I’m only doing what I have in shop. I need to get current home ready to sell, listed, and then I can maybe do some building of o don’t start on the garage extension build right away on the new house. Gonna be busy until May, at least. I still offer the DVD (IMG:style_emoticons/default/wink.gif) |
cary |
Feb 9 2018, 11:22 PM
I have your DVD and written word all set to go for Mike ............
cary |
Feb 15 2018, 09:23 AM
Update : We ended Saturday just about ready to reinstall. (AX Annual Tech for the Carrera in the am) While we had it out , again. It got a new alternator harness. Its going to get a new ignition harness too, but I'll need to do a conversion to a 72 today. Sorry to say the heater wires will have ride on the outside. But they'll be new and fresh.
Hopefully 10 years hasn't jinxed my spare gear box and Mike will be driving home tomorrow. He's talking about taking it down to Route 66. That would give him a some time with the dye kit in the engine oil to help us (me) find the oil leak(s). Filter was about a 1/4 to 1/3 turn loose, hopefully that was it. |
cary |
Feb 17 2018, 08:21 AM
On his way home .................... with his borrowed gear box.
Hit the linkage adjustment dead on first shot. Chris bungee cord in neutral He'll be back this afternoon to box up his spare parts. I'm going to tune his window frame so they fit tight to the windshield frame. Clutch needs some adjustment. Jacked out and to the left. Goofy ............ While the pedal cover is off I'll set the brake pedal free play to spec. Then we'll see if he wants a little tune on the pedal free play. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:26 PM |
