Problem with fuel gauge., Shows only 1/4 full. |
daytona |
Feb 4 2018, 03:48 PM
daytona Group: Members Posts: 435 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi world,
I need some help with the fuel gauge in my 74. The car is a 6 cylinder conversion but I don't think that this factor contributes to the problem. The issue is that the gauge shows that the tank is 1/4 full even though it is full to the top. I have two other gauges that I tried and both show the same 1/4 tank level. In my book this would indicate that the sending unit is the culprit. Couldn't be that all three gauges have the same defect. However, measuring the voltage at the gauge, I get 12.4VDC. I think this means that the sending unit is sending the correct signal. So where is the problem??? Has anyone had this problem? Any ideas? Any and all help is appreciated. Thanks, Bill. |
dr914@autoatlanta.com |
Feb 4 2018, 03:50 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Remove the sending unit, take it apart, and clean the fireman's pole that the float sides up and down upon. An easy fix, the pole gets corroded and the float will not slide up and down
Hi world, I need some help with the fuel gauge in my 74. The car is a 6 cylinder conversion but I don't think that this factor contributes to the problem. The issue is that the gauge shows that the tank is 1/4 full even though it is full to the top. I have two other gauges that I tried and both show the same 1/4 tank level. In my book this would indicate that the sending unit is the culprit. Couldn't be that all three gauges have the same defect. However, measuring the voltage at the gauge, I get 12.4VDC. I think this means that the sending unit is sending the correct signal. So where is the problem??? Has anyone had this problem? Any ideas? Any and all help is appreciated. Thanks, Bill. |
daytona |
Feb 4 2018, 04:01 PM
dr914, OK thanks.
So you are saying that as the float goes up, the resistor should send less volts? Essentially empty = 12V, and full = somewhat less then 12V ? Thanks, Bill. |
Feb 4 2018, 04:07 PM
0-90 ohms resistance to the gauge, When it gets stuck nine times out of ten it is the sliding float, once in a while the wire breaks and then you can solder it back together
dr914, OK thanks. So you are saying that as the float goes up, the resistor should send less volts? Essentially empty = 12V, and full = somewhat less then 12V ? Thanks, Bill. |
GeorgeRud |
Feb 4 2018, 05:38 PM
The sender is basically a variable resistor, so you could measure the resistance (in ohms) while moving the float up and down. As noted, it should read from 0 to 90 ohms(or there about).
Tbrown4x4 |
Feb 5 2018, 06:01 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Some of your terminology is off, so hopefully this helps:
The gauge should have battery voltage to it, and the sending unit provides the ground circuit. It has a float that rides up and down on a guide rod. The float has contacts (wipers) that run on resistor wires in the sending unit. When the fuel level is high, the resistance is low. More current flows through the fuel gauge, and it shows a high fuel level. When the fuel level is low, there is more resistance, so more less current flows through the gauge, and it shows a low level. Like George said, the most likely problem with a gauge reading low is the float stuck on the guide rod. Mine would stick on 3/4 full until I hit a bump, then it would read correctly for a while. These cars can sit, and condensation in the fuel tank causes the rod to rust and keep the float from moving freely. Take it apart and clean it. Just be careful of the resistor wires. They are very fragile. And replace the gaskets. |
daytona |
Feb 5 2018, 03:40 PM
daytona |
Feb 5 2018, 05:25 PM
Anybody?
I removed the small nut on the bottom of the sender but it is not coming apart. What am I doing wrong? Any suggestions? Thanks, Bill. |
Olympic 914 |
Feb 5 2018, 05:34 PM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Yes. remove the little nut on the bottom, carefully slide the tube off. you will see the "firemans pole" George spoke of and two VERY fine wires. do not put any pressure on these wires they will stretch easily and sag or worse, break. you can clean them with carb cleaner and a q-tip. then use fine sandpaper on the center pole.
did I say CAREFULLY enough ? mine would hang up in different spots and this fixed it. |
daytona |
Feb 5 2018, 06:41 PM
I have not been able to take it apart yet. I have taken the small nut out at the bottom but the tube still will not slide off. I guess I need undo the crimped area that holds the tube to the plastic part at the bottom.
I did measure the resistance at the pins and it goes from 54 Ohms with the flow at the top, to 70 Ohms with the float at the bottom of the sender. I know that the Dr. mentioned 0 to 90 Ohms. If that is the target this sender is way off. Bill. |
windforfun |
Feb 5 2018, 06:48 PM
Senior Member Group: Members Posts: 1,787 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
You can get a brand new OEM Bosch unit for about $150 on the internet.
Tbrown4x4 |
Feb 5 2018, 08:52 PM
I just had mine apart, and I don't remember having to un-crimp the bottom. I think if you gently wiggle the tube back and forth, it separated at the top. It has been on there for 40+ years!
BTW, my sending unit had 66.9 ohms empty and 9.2 ohms full. |
PanelBilly |
Feb 5 2018, 09:07 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I bought a new one from Sunset Porsche. It’s s nice to know how much fuel you have especially the way these /6 cars consume it.
daytona |
Feb 6 2018, 12:16 PM
Hi again guys,
Last knight I was just being an idiot but I did finally figure out that the tube separated from the top mounting. Attached are some photos of the inner part of the sending unit. To me it looked absolutely clean. The center pole was shiny like polished stainless, and the three wires were intact. The float moves freely and when I measured the resistance again now it read 70 Ohms at empty and 6.4 Ohms in the full tank position. The thing is that this sending unit was also showing 1/4 tank even when full. I am beginning to think that the wires are in the wrong position at the gas gauge. Can anyone confirm the correct position of the wires at the gouge? I looked at the factory shop manual electrical diagram but it does not show which prong each wire connects to. Thanks, Bill. |
TheCabinetmaker |
Feb 6 2018, 12:38 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Your connectors should be in a plug that only plugs in one way
daytona |
Feb 6 2018, 06:34 PM
Cabinetmaker,
Yes, that is the plug at the sending unit, thanks. But I would like confirmation of the wire positions at the fuel gauge. Bill. |
Mike Fitton |
Feb 6 2018, 07:09 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Here you go.
daytona |
Feb 7 2018, 06:17 AM
Thank you Mike.
Bill. |
Morrie |
Feb 7 2018, 09:57 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Hi Guys,
My connector at the sending unit was broken.. My gauge sits on E. I will be pulling the sender as above. Can someone give me the correct wire locations / colors for the connector so I can verify wiring at the sender end? |
daytona |
Feb 11 2018, 06:12 PM
Hi all,
fuel gauge problem solved. As several of you suggested it was indeed the sending unit. The spare sending unit did the trick. Thank you all for the help. Bill. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:11 PM |
