FS: /4 stub axels, * Featured Item * |
914werke |
Feb 5 2018, 07:22 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If youve ever towed or moved your car w/ .5 shafts removed you run the risk of
wrecking the R. wheel bearings. (IMG:style_emoticons/default/sad.gif) Here is the answer. A spare set of stub axles (IMG:style_emoticons/default/aktion035.gif) Hardware included when available. Several sets available (available individualy as well) Available HERE (IMG:style_emoticons/default/bye1.gif) Attached image(s) |
BuddyV |
May 23 2018, 01:04 PM
Robert Group: Members Posts: 553 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
OK.... I need help with this..... I have replaced rear bearings, so I can picture the rear set up. What is the problem towing without the 1/2 shafts attached?
I want to avoid having to re-do those suckers as best I can. Please explain..... sounds like you solved a problem I was not aware existed. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th April 2024 - 02:19 AM |
