FS: /4 stub axels, * Featured Item * |
914werke |
Feb 5 2018, 07:22 PM
"I got blisters on me fingers" Group: Members Posts: 9,995 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If youve ever towed or moved your car w/ .5 shafts removed you run the risk of
wrecking the R. wheel bearings. (IMG:style_emoticons/default/sad.gif) Here is the answer. A spare set of stub axles (IMG:style_emoticons/default/aktion035.gif) Hardware included when available. Several sets available (available individualy as well) Available HERE (IMG:style_emoticons/default/bye1.gif) Attached image(s) |
914work |
May 23 2018, 01:13 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Ill give this a shot, you CAN tow w/o the .5 shafts as long as stubs are installed.
The rear bearings are "Split bearings" effectively two races in a shell that are only held ridged when the shaft of the stub axle is installed, without that support they can come apart. |
Lo-Fi Version | Time is now: 18th April 2024 - 05:19 PM |
