Best Suspension Setup, For a good handling street car |
Justinp71 |
Feb 8 2018, 10:33 AM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
So since a lot of us on here are trying to achieve a well handling street car, that still absorbs bumps. I figure it would be good to share suspension setup's. I will go first-
Front- 18mm torsion bars (stock 914) 19mm sway bar, set to second hole out Bilsteins (sport) Stock Bushings 205/50/15 tires Rear- 200 lb springs w/coil-overs (3.2l motor) no sway bar Bilsteins (sport) 225/45/15 tires I do have a six, so my spring rates in the rear need to be a little higher. This combo for me seems to work really well for a street car with occasional track use. It could benefit from maybe 19 or 20mm front torsion bars. Btw this combo feels "softer" than my GTi, yet it still handles well on the track (for occasional HPDE use). Interesting I have heard if you order Koni's you can get them made for a 914 (since it is different weight than a 911). What works for you guys? |
defianty |
Feb 8 2018, 11:48 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
I can't comment on the ride yet as the car isn't built yet, but this is what I have already purchased for the car. My decisions were based on research and advice from a friend who raced a 914.
Front- 21mm Torsion bars 19mm Sway bar Bilstein Sport Shocks Stock Bushings Rear- 200 lb Springs adjustable coil-overs (3.0l motor) 16mm Sway bar - (Will decide whether to keep after testing) Bilstein Sport Shocks |
Lo-Fi Version | Time is now: 19th April 2024 - 04:54 PM |
