Sold: Set of Rear Caliper Covers / Dust Shields, Porsche 911 |
914_7T3 |
Feb 8 2018, 11:26 AM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,847 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Recently purchased these for my 914 and turns out they correct for an early 911 with slotted rotors. In very good condition with original plating still showing and hardware.
These will clean up nicely with a fresh plating. $65.00 for the pair plus applicable shipping or local pick up in Sherman Oaks, CA |
burton73 |
Feb 8 2018, 01:55 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Hi Jeffery,
I have some 4-cylinder parts that you may need but one needs to be straitened out a little and I can use the set you have for an early 6 for my set for early 6 parking brakes Bob B |
burton73 |
Feb 8 2018, 01:56 PM
So yes I need yours
914_7T3 |
Feb 8 2018, 02:32 PM
So yes I need yours They’re yours now. We can sort it out later (IMG:style_emoticons/default/beerchug.gif) |
burton73 |
Feb 8 2018, 08:36 PM
So yes I need yours They’re yours now. We can sort it out later (IMG:style_emoticons/default/beerchug.gif) Bruce stone called me and told me that the early 911 brake backing plate that you have and all 911 backing plates will not fit the 914 trailing arm. Totally different bolt up set up and the shape is not the same. I think you will need to find a home for that part on early S or on the Pelican site, as it will not work for 914s. Sending you a PM Bob |
914_7T3 |
Feb 8 2018, 11:29 PM
So yes I need yours They’re yours now. We can sort it out later (IMG:style_emoticons/default/beerchug.gif) Bruce stone called me and told me that the early 911 brake backing plate that you have and all 911 backing plates will not fit the 914 trailing arm. Totally different bolt up set up and the shape is not the same. I think you will need to find a home for that part on early S or on the Pelican site, as it will not work for 914s. Sending you a PM Bob Currently listed on Pelican and the Samba for 911s if anyone needs them. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:54 PM |
