Would you remove the windshield to replace the dash and dash cap? |
98101 |
Feb 9 2018, 08:41 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
Sorry if you saw this same question on another thread. I either missed the answer, or people have been reluctant to answer.
I've got to replace the dash metal (vinyl, etc.) and would kinda like to do the dash cap at the same time. Mine is a 1970 that doesn't have the vent holes on the sides that people use for access. I understand it's much easier with the windshield out, but if your windshield is OK, would you remove it just to do this? |
98101 |
Feb 10 2018, 02:47 AM
Cool. Thank you all for the advice. I know dash top cracks are normal, but I'm looking forward to not having them anymore.
sixaddict |
Feb 10 2018, 08:03 AM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
So you already have the answer, but Chris914 was not being honest (IMG:style_emoticons/default/dry.gif) it is PITA...I described the job to one of the shops I use as wanting to cry ....and he said " oh you changed the dash" ...plan on gnashing of teeth and pain as you work this one through unless the have small hands...There is a Brad Mayeur video on here somewhere showing the process you should play but recognize where he is doing it and the contortionist you will need to be to do it.
Here is my suggestion....Have a comprehensive set of 1/4 drive ratchet/extensions and an LED light to strap to your head. I also pull the seats out for space. Lastly I am curious---- did you get your 70 dash pad repaired/ refurbished as I have one I need and cant find anyone to do it correctly. Good luck and just like the doctor at prostate exam time, I hope you have small hands! (IMG:style_emoticons/default/evilgrin.gif) quote name='98101' date='Feb 10 2018, 12:47 AM' post='2577294'] Cool. Thank you all for the advice. I know dash top cracks are normal, but I'm looking forward to not having them anymore. [/quote] |
98101 |
Feb 10 2018, 02:35 PM
So you already have the answer, but Chris914 was not being honest (IMG:style_emoticons/default/dry.gif) it is PITA...I described the job to one of the shops I use as wanting to cry ....and he said " oh you changed the dash" ...plan on gnashing of teeth and pain as you work this one through unless the have small hands...There is a Brad Mayeur video on here somewhere showing the process you should play but recognize where he is doing it and the contortionist you will need to be to do it. Here is my suggestion....Have a comprehensive set of 1/4 drive ratchet/extensions and an LED light to strap to your head. I also pull the seats out for space. Lastly I am curious---- did you get your 70 dash pad repaired/ refurbished as I have one I need and cant find anyone to do it correctly. Good luck and just like the doctor at prostate exam time, I hope you have small hands! (IMG:style_emoticons/default/evilgrin.gif) OK. Thanks for the warning! I don't have small hands, don't have good coordination, good tools, and not much experience with this. I think I'd be in over my head doing this. On Monday I have an appointment with a local shop that was restoring another 914 when I toured. I'll probably order new dash metal and vinyl from 914Rubber because my current dash has gauges in the spot the heater controls will be returning to. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:58 AM |
