Teen 914 build, My first car ever at 18, and what im attempting to complete |
camgraves3113 |
Feb 10 2018, 12:40 AM
Graves31 Group: Members Posts: 60 Joined: 8-January 18 From: canton CT Member No.: 21,773 Region Association: None |
I purchased two 73 914’s, for 3200 total. Great price, i believe but both cars are beautiful fust buckets. Tons of laborious work ahead. Here’s original photos from about 2 months ago (IMG:style_emoticons/default/beerchug.gif)
Attached thumbnail(s) |
camgraves3113 |
Mar 6 2018, 08:36 PM
THANK you everyone, me and my dad were able to drop it out without even cutting nor drilling any bolt whatsoever. So i had the car up on 1 cinderblock high, and basically, using two jacks on either side of the engine mounting large bracket. Bye doing this, there was no down pressure on the bar which was ultimately holding the nut in the deepest part of the oddly located and shaped (cover?)-holding the nut and bolt on either sides. BECAUSE of this, i was finally able to get my hand and a wrench on the nut, and a socket on the bolt.
Also bye jacking the bar, with two jacks close to the middle (leaving the bolt and nut accessible) basically, only the top of the bolt is threaded, so i was able to push up on the bolt, and push it in farther, allowing the nut to be raised and provide easy access. Sorry if i am hard to understand, i am surely not majoring in english!! Haha All in all, i am very thankful for the 914 community and support, as i was able to make huge progress today. Now i get to work with the motor and get the baby cleaned out (it is a bored out 1.7L to a 2litre) and looking and sounding good. In the next few posts i am going to provide images to respresent my directions ^ and hopefully make this adventure more informative for whomever reads this thread (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
Dave_Darling |
Mar 7 2018, 01:31 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
(it is a bored out 1.7L to a 2litre) That is commonly referred to as a "1.9" or a "1911" (which is the displacement in CC of a 96mm bore and the stock 66mm stroke). A 2.0 motor is 94mm bore X 71mm stroke, for 1971cc displacement. Calling your 1911 a "2 liter" is a bit of a misrepresentation. --DD |
camgraves3113 |
Mar 7 2018, 01:57 PM
(it is a bored out 1.7L to a 2litre) That is commonly referred to as a "1.9" or a "1911" (which is the displacement in CC of a 96mm bore and the stock 66mm stroke). A 2.0 motor is 94mm bore X 71mm stroke, for 1971cc displacement. Calling your 1911 a "2 liter" is a bit of a misrepresentation. --DD Very interesting, as i will admit i at this point i am very ill informed regarding engine specifications, compression rates, and ect. Thank you for pointing this out I appreciate any info you have to offer |
Lo-Fi Version | Time is now: 26th April 2024 - 08:07 PM |
