Teen 914 build, My first car ever at 18, and what im attempting to complete |
camgraves3113 |
Mar 8 2018, 03:07 PM
Graves31 Group: Members Posts: 60 Joined: 8-January 18 From: canton CT Member No.: 21,773 Region Association: None |
And lastly, this grease covored oily mess
Attached thumbnail(s) |
jd74914 |
Mar 8 2018, 03:34 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Those RH intake ports don't look so hot...is that white stuff corrosion and does it run the whole way down the port?
camgraves3113 |
Mar 8 2018, 04:00 PM
camgraves3113 |
Mar 8 2018, 05:39 PM
Worked on cleaning it up with purple power luquid, metal bristled brushes, and some elbow grease. Got to admit, it barely seems to look any better. I wish i could power wash it, or would that be too harsh to the crevices of a bare engine? Any tips or tricks would be great
Mar 8 2018, 06:35 PM
For the engine tin screws, I have found a few things that help.
1- Get the correct size screwdriver. I know they're just slot-head screws, but if you get a driver that fits the slot snugly it helps. I found that the largest screwdriver I could find at my local Sears was the correct size. If you can, take one of the engine tin screws with you to check the fit against the screwdrivers in the store or in your Best Friend's tool collection. 2- Impact can help. Put the driver in the screw, then give the handle end of the driver a sharp rap with a mallet. This can, sometimes, help break a bond between the fastener and what it is screwed into. 3- Use a good penetrating oil. Liquid Wrench is OK, WD-40 is not. I like PB Blaster and Kano's Aero Kroyl. Others have said that paraffin also works if you heat the fastener. 4- Which leads us to the other big thing, heat. The "hot wrench" can help break the bond between parts. Use with caution, and make sure to have a fire extinguisher handy. --DD |
Mar 8 2018, 06:42 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lots of heat and then the paraffin/wax as it cools. The heat wicks in the wax. Works well.
porschetub |
Mar 8 2018, 09:25 PM
Those RH intake ports don't look so hot...is that white stuff corrosion and does it run the whole way down the port? (IMG:style_emoticons/default/agree.gif) not good don't expect too much ,outside stored motor,generally not a great out come,bottom end might be ok??? In this case I would say the pistons will be seized in the bores (IMG:style_emoticons/default/sad.gif) . |
camgraves3113 |
Mar 8 2018, 10:42 PM
Thank you guys so much, i will try all the suggested techniques, and update you all on the outcome!
jd74914 |
Mar 9 2018, 07:07 AM
I'd highly suggest going out and buying an impact screw driver to remove engine tin screws (also work well for the rotor screws, etc). When you hit them with a hammer they rotate slightly so the turning is perfectly timed with the impact; I've rarely stripped a tough screw using one. You can buy Lisle 3/8" one at sears or off Amazon for ~$20 and it's worth every penny.
camgraves3113 |
Mar 9 2018, 06:37 PM
Sadly on the other intake, some bolts are stripped, and i am currently trying to get them out
camgraves3113 |
Mar 10 2018, 06:40 PM
Also, for everyone that is interested, i have some 914 things up so far, but i am about to offer many more parts (refurbished) on ebay!!
Here is my link; My Webpage https://ebay.com/usr/cagrave-0 |
camgraves3113 |
Mar 10 2018, 08:59 PM
Also, is it correct for the intakes farthest nut (closest to the tranny) to be a different size? It could be that mines so rusted and deformed, but it seems to me to be genuinely smaller than the other three 13mm bolts that bolt the piped on. Im just curious!! (IMG:style_emoticons/default/smile.gif)
camgraves3113 |
Mar 11 2018, 01:25 PM
Still have yet to touch this guy!!!! Haha, the parts are beautiful though i am very excited to eventually get to it
camgraves3113 |
Mar 13 2018, 02:07 PM
Does anyone have a pro and con list of shocks and struts compared to the price. I want to go with KYB gas adjust, is that ok for performance?
Mar 13 2018, 02:31 PM
Does anyone have a pro and con list of shocks and struts compared to the price. I want to go with KYB gas adjust, is that ok for performance? No. If you want performance shocks, go billstein or koni. If you want economical and good street driving go Boge. If you can only afford kyb’s, save your money until you can spend more. |
camgraves3113 |
Mar 13 2018, 10:49 PM
Does anyone have a pro and con list of shocks and struts compared to the price. I want to go with KYB gas adjust, is that ok for performance? No. If you want performance shocks, go billstein or koni. If you want economical and good street driving go Boge. If you can only afford kyb’s, save your money until you can spend more. I appreciate it. I do have the money, but i dont really understand the difference in the shocks and struts from one to another |
3d914 |
Mar 14 2018, 01:16 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Does anyone have a pro and con list of shocks and struts compared to the price. I want to go with KYB gas adjust, is that ok for performance? No. If you want performance shocks, go billstein or koni. If you want economical and good street driving go Boge. If you can only afford kyb’s, save your money until you can spend more. I appreciate it. I do have the money, but i dont really understand the difference in the shocks and struts from one to another I second mepstein's advice. Went with Billstein and never regretted it. |
camgraves3113 |
Mar 16 2018, 01:11 PM
Trying to get better at refurbishing parts in general. I am pretty excited about this blower/heater
camgraves3113 |
Mar 16 2018, 01:12 PM
Another pic
camgraves3113 |
Mar 16 2018, 01:13 PM
3.. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 25th April 2024 - 12:13 AM |
