SOLD FS: L-Jet fuel injection |
Cevan |
Feb 10 2018, 12:40 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
SOLD
this came off an excellent running '75 1.8 with ~70,000 miles (I installed a 2056 with carbs). - AFM - airbox - plenum with throttle body, temp sensor, throttle position sensor - resistor pack - intake tubes with injectors and spacers - fuel pressure regulator - ECU - wiring harness with dual relay - fuel pump - AAR - AFM to plenum tube Also an extra AFM to plenum tube, AFM, and ECU. I do not know the condition of these extra parts. $300 plus shipping. |
davesprinkle |
Feb 10 2018, 03:42 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
This came off an excellent running '75 1.8 with ~70,000 miles (I installed a 2056 with carbs). - AFM - airbox - plenum with throttle body, temp sensor, throttle position sensor - resistor pack - intake tubes with injectors and spacers - fuel pressure regulator - ECU - wiring harness with dual relay - fuel pump - AAR - AFM to plenum tube Also an extra AFM to plenum tube, AFM, and ECU. I do not know the condition of these extra parts. $300 plus shipping. You know a 2056 will run great with L-jet, right? No need to step back to carbs. |
74ravenna |
Feb 10 2018, 05:33 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
pm sent
Cevan |
Feb 10 2018, 07:50 PM
Lo-Fi Version | Time is now: 16th May 2024 - 10:25 PM |
