WTB: Shift rod for 6 conversion, side shift trans, Got one sitting around? |
koozy |
Feb 11 2018, 10:38 PM
Senior Member Group: Members Posts: 646 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I'm looking for a shift rod for 6 conversion, side shift trans. Does anyone have one sitting around?
Thanks, Mike |
deemsriddle |
Feb 12 2018, 07:35 AM
Newbie Group: Members Posts: 15 Joined: 1-January 17 From: Ringgold GA Member No.: 20,717 Region Association: South East States |
I am building a 914/4. I was pressing the pin out of my old shifter to replace the bushing in the U-joint and it exploded. No kidding. I probably should had shot it with penetrating oil, but there was no sign of corrosion. Save yourself a lot of grief and buy new from Tangerine racing. It looks to be a superior product anyhow. The gear shift linkage in 914s were horrible in the first place.
koozy |
Feb 12 2018, 09:42 AM
Sorry to hear that happened to you. I've pulled the pin on those many times. Not the funnest job. I was making the same type of shift linkage mods as Chris at Tangerine for many years before he was offering them so I am just looking for the rod. I figured if someone already has one that they don't need any more it will save me some time.
rgalla9146 |
Feb 12 2018, 12:07 PM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is what you're looking for ?
This is fabricated using the front and rear parts of a standard side shift rear piece. The small curves and straight portion are clipped from a rear shifter, rear part. It's needed for my car. This can be done many ways. It must be accurate. Attached thumbnail(s) |
bdstone914 |
Feb 12 2018, 01:06 PM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am building a 914/4. I was pressing the pin out of my old shifter to replace the bushing in the U-joint and it exploded. No kidding. I probably should had shot it with penetrating oil, but there was no sign of corrosion. Save yourself a lot of grief and buy new from Tangerine racing. It looks to be a superior product anyhow. The gear shift linkage in 914s were horrible in the first place. The couplers are fragile and will no take much pressure without breaking. I had a shift rod with a stuck pin, Heated it with a torch do soften and dig out the bushings. Then heated with a Map gas torch trying to direct to heat on the pin and not the aluminum coupler. With the bushings out you can insert a socket through the coupler to contacting the square block. With it supported there you can use a vise or BFH and punch to loosen the pin. Worked it back and forth until the pin cam out. Nice billet couplers are made fir 911 which work in a 914. https://www.pelicanparts.com/cgi-bin/ksearc...r=STOMSKI-SR010 |
bdstone914 |
Feb 12 2018, 01:08 PM
koozy |
Feb 12 2018, 01:13 PM
Yes, rgalla9146 that is what I am looking for. How much do you want for it?
rgalla9146 |
Feb 12 2018, 02:40 PM
Yes, rgalla9146 that is what I am looking for. How much do you want for it? I fabricated it for my car. It's not for sale. If you have no luck elsewhere and can provide the described parts I'd be willing to make one for you. But.... your headers and possibly other factors will have to be considered. Where are you ? Rory |
koozy |
Feb 12 2018, 02:44 PM
Yes, rgalla9146 that is what I am looking for. How much do you want for it? I fabricated it for my car. It's not for sale. If you have no luck elsewhere and can provide the described parts I'd be willing to make one for you. But.... your headers and possibly other factors will have to be considered. Where are you ? Rory I'm in California. Thanks for the offer, I appreciate it. |
Lo-Fi Version | Time is now: 28th March 2024 - 02:25 PM |
