> SS Exhasut Nut Update, Installed and Took Pictures
914Sixer
post Feb 12 2018, 07:05 PM
It warmed up enough today to go the the warehouse and try these out. I like the way they fit up and that the heads are 12mm. Factory nut are 13mm head. I was able to install them using a 12mm wobbel socket. The SS nut covers the entire flange of the SS heat exchangers.
rgalla9146
post Feb 13 2018, 10:00 AM
QUOTE(914Sixer @ Feb 12 2018, 08:05 PM) *
They look stainless....are they ?
Is the washer part of the nut or a separate piece ?
Looks like the perfect solution.
914Sixer   SS Exhasut Nut Update   Feb 12 2018, 07:05 PM
gothspeed   they look great! will they get retightened/ch...   Feb 12 2018, 07:16 PM
914Sixer   Engine is still on the stand. Waiting on the ne...   Feb 12 2018, 07:38 PM
rgalla9146   It warmed up enough today to go the the warehouse...   Feb 13 2018, 10:00 AM
Dave_Darling   Is there any locking feature built in? --DD   Feb 13 2018, 10:16 AM
rhodyguy   Those are on a set of headers or he's? Mark sh...   Feb 13 2018, 10:19 AM
UROpartsman   Looks good, are the studs standard or also stainle...   Feb 13 2018, 10:33 AM
sfrenck   I used 316SS serrated M8 nuts from Amazon - haven...   Feb 13 2018, 11:24 AM
914Sixer   Test studs are stock. Not sure what Len is going ...   Feb 13 2018, 12:41 PM
UROpartsman   Be sure to use plenty of anti-seize whenever using...   Feb 13 2018, 12:57 PM
914Sixer   Update: BelMetric has stock size M8x56 stainless ...   Feb 15 2018, 11:10 AM
Mueller   I think these nuts are titanium based on that othe...   Feb 15 2018, 11:51 AM
Optimusglen   I'd be very concerned about galling of the thr...   Feb 15 2018, 12:39 PM
UROpartsman   I'd be very concerned about galling of the th...   Feb 15 2018, 04:05 PM
914_teener   I'd be very concerned about galling of the t...   Feb 15 2018, 06:52 PM
UROpartsman   When you drill stainless you are work hardening t...   Feb 15 2018, 07:16 PM
914_teener   When you drill stainless you are work hardening ...   Feb 15 2018, 08:52 PM
914_teener   ......oh yea....the other factoid thing I read.......   Feb 15 2018, 07:15 PM
- Lo-Fi Version Time is now: 16th April 2024 - 12:25 AM
