SS Exhasut Nut Update, Installed and Took Pictures |
914Sixer |
Feb 12 2018, 07:05 PM
914 Guru Group: Members Posts: 8,840 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
It warmed up enough today to go the the warehouse and try these out. I like the way they fit up and that the heads are 12mm. Factory nut are 13mm head. I was able to install them using a 12mm wobbel socket. The SS nut covers the entire flange of the SS heat exchangers.
Attached image(s) |
Optimusglen |
Feb 15 2018, 12:39 PM
Senior Member Group: Members Posts: 901 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I'd be very concerned about galling of the threads, better hope you never have to remove those unless you went nuts with anti seize. Even if you did, I'd be a little worried.
Lo-Fi Version | Time is now: 28th March 2024 - 03:34 AM |
