My 7mm Caliper bolt solution |
n2j2ryan |
Feb 12 2018, 10:14 PM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
After many suggestions and a visit to a machine shop, I decided with this solution. I tapped out one end from the 7mm hole to a an 8mm thread. The other end I just bored out to 8mm. It now takes an 8mm socket head bolt, without a nut, just like the later callipers. Total cost of all bolts $12, instead of the $16 per bolt plus delivery from the UK.
oldie914 |
Feb 13 2018, 12:11 PM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
I think Ate used the odd bolt size to keep somebody from rebuilding the calipers with the wrong (low strength) bolts. 7mm is a very strange bolt size and was probably only available from Ate. I am sure they would not sell them to everybody back then.
The calipers on my 1997 Mercedes are attached with bolts with 18mm heads. I think it has the same purpose. |
Lo-Fi Version | Time is now: 28th March 2024 - 05:13 PM |
