considering replacing the backpad with carpet?Update Completed wanted to share pics, backpad replace |
May 22 2018, 01:47 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes. |
mb911 |
May 22 2018, 02:01 PM
914 Guru Group: Members Posts: 6,750 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes. I went with a charcoal carpet so grey will work perfect for me.. Good to know.. |
May 22 2018, 02:10 PM
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes. I went with a charcoal carpet so grey will work perfect for me.. Good to know.. There is someone selling the grey kits on eBay. I like the smoother look of molding one piece to the firewall but I’m sure the kit looks fine. I’ve never been a fan of the puffy backpad but I guess it was sort of needed to make the 2+1 seating. |
xperu |
May 23 2018, 09:18 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad antd maybe fill the screw holes. I went with a charcoal carpet so grey will work perfect for me.. Good to know.. There is someone selling the grey kits on eBay. I like the smoother look of molding one piece to the firewall but I’m sure the kit looks fine. I’ve never been a fan of the puffy backpad but I guess it was sort of needed to make the 2+1 seating. I bought mine on Ebay several months ago. Pre-cut and stitched. It fits very good. Mike |
bajafreaks |
Jun 28 2023, 05:09 PM
Member Group: Members Posts: 66 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
Digging up this older thread.
No one has mentioned if there was a difference in engine /cabin noise going this route. Dynamat and perlon is the noise level comparable to stock padding etc.? |
Justinp71 |
Jun 28 2023, 06:38 PM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I was looking at this thread too @jrblackbox did you go with the ebay carpet kit? |
blabla914 |
Jun 28 2023, 07:14 PM
I like primer Group: Members Posts: 320 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes. When I bought my perlon carpet set from Mike I just asked for extra material to do the firewall. He sent me an extra piece of matching perlon with no backing. I put it on over sound deadening material using spray adhesive. The only part in the least bit tricky is the joint of the carpet up against the window. I made a template out of a bunch of pieces of paper taped together and then put that on the fabric to match the profile of the window. otherwise the unbacked perlon forms easily to the contour of the firewall with no wrinkles. piece of cake. For lighting I cut a 911 light in down low on the firewall just above the tunnel. works great. |
bkrantz |
Jun 28 2023, 08:35 PM
914 Guru Group: Members Posts: 7,667 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Digging up this older thread. No one has mentioned if there was a difference in engine /cabin noise going this route. Dynamat and perlon is the noise level comparable to stock padding etc.? I used Dynamat plus a layer of foam Dynaliner under perlon on the inside, and then replaced the stock pad on the engine side with a foil-foam sandwich. It's not "quiet" but not at all loud. Most of what I hear (with the top on) comes through the rear window glass. |
Bullethead |
Jun 28 2023, 08:43 PM
Oil Cooled heart Group: Members Posts: 889 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
When I bought my perlon carpet set from Mike I just asked for extra material to do the firewall. He sent me an extra piece of matching perlon with no backing. I put it on over sound deadening material using spray adhesive. The only part in the least bit tricky is the joint of the carpet up against the window. I made a template out of a bunch of pieces of paper taped together and then put that on the fabric to match the profile of the window. otherwise the unbacked perlon forms easily to the contour of the firewall with no wrinkles. piece of cake. For lighting I cut a 911 light in down low on the firewall just above the tunnel. works great. @blabla914 Please post an image of your lighting solution... looking for an alternative to underdash. Thanks! |
jrblackbox |
Jun 29 2023, 05:01 AM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
No kit, just the perlon fabric off ebay from appbiz I believe over dynamat. |
Geezer914 |
Jun 29 2023, 10:09 AM
Geezer914 Group: Members Posts: 1,358 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I did Perlon on the back wall behind the seats. Installed Dynamite to the firewall in the engine compartment and covered that with a thin silver covered firewall blanket. Installed 2 small led interior lights on each side of the center console with the 3 gauges.
bajafreaks |
Jun 29 2023, 01:35 PM
I did Perlon on the back wall behind the seats. Installed Dynamite to the firewall in the engine compartment and covered that with a thin silver covered firewall blanket. Installed 2 small led interior lights on each side of the center console with the 3 gauges. Hows the sound inside the cabin ? |
Geezer914 |
Jun 29 2023, 03:40 PM
I have a Triad exhaust, not too loud with the windows up. It's a Porsche, not a Cadillac limo!
blabla914 |
Jun 30 2023, 03:18 PM
[/quote] @blabla914 Please post an image of your lighting solution... looking for an alternative to underdash. Thanks! [/quote] The lighting isn't as good as stock as it's down low, but it does the job. The wiring is easy. Just snake the original wiring and trim to length. Key is mount as high as possible on the lower part of the firewall. You can kind of see the edge of what I'm talking about thorough the fabric. There are a bunch of layers of metal in there, especially down low, but you don't want to interfere with the center tray. The 911 light is kinda expensive, but it's much nicer than the stock vw unit and seems to give off quite a bit more light. I can't take credit for this. I saw it somewhere. perhaps on Serrano's site. |
Geezer914 |
Jun 30 2023, 03:54 PM
Under dash lights in center gauge consol.
Ottomotion |
Jun 30 2023, 08:22 PM
Newbie Group: Members Posts: 45 Joined: 12-January 23 From: Central California Member No.: 27,090 Region Association: None |
Sorry if this has already been asked, but do you get more seat travel adjustment rearward with this mod and if so, about how much?
bahnzai |
Jul 1 2023, 06:51 AM
Member Group: Members Posts: 304 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
bahnzai |
Jul 1 2023, 06:54 AM
@914dave
Maybe Dave will reply with some details on his firewall cover and interior light. Although, knowing Dave…the light/mount is handcrafted, like most of his build! |
914dave |
Jul 1 2023, 08:28 PM
914 Addict Group: Members Posts: 699 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Lo-Fi Version | Time is now: 29th March 2024 - 06:16 AM |
