Could use some help on removing dahs switches |
Tdskip |
Feb 13 2018, 03:49 PM
Got the cigarette lighter out, but how do the other switches come off? Unscrew the pull and then somehow remove the plate that is external OR does the switch pull out towards the interior?
I should know this from the 911 and 928 but... |
SirAndy |
Feb 13 2018, 03:51 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The switches pull out the back but you need a special wrench to unscrew the front clamp ring. Or use a larger coin to fit in the two grooves.
(IMG:style_emoticons/default/smash.gif) |
Tdskip |
Feb 13 2018, 03:58 PM
The switches pull out the back but you need a special wrench to unscrew the front clamp ring. Or use a larger coin to fit in the two grooves. (IMG:style_emoticons/default/smash.gif) Ah, got it. Thanks Sir, er Andy, wr Sir Andy. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:17 PM |
