Could use some help on removing dahs switches |
Tdskip |
Feb 13 2018, 03:49 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Got the cigarette lighter out, but how do the other switches come off? Unscrew the pull and then somehow remove the plate that is external OR does the switch pull out towards the interior?
I should know this from the 911 and 928 but... |
Dave_Darling |
Feb 13 2018, 10:20 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I have used a pair of needle-nose pliers in the holes, or in the slot across the center of the "escutcheon" (which is what the manual calls that flat nut). Once the escutcheon is loose, you can spin it off with your fingers, and then the switch body comes out toward the inside of the dash.
--DD |
Lo-Fi Version | Time is now: 7th May 2024 - 10:53 AM |
