Check your brake hoses. |
cal44 |
Feb 13 2018, 04:50 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
I am changing out brake hoses on a '74. "The dates are on the hoses for a reason"
. The hoses removed were dated 1988. The prior owner didn't do his own work so I am amazed that his regular wrench didn't bother to look. Thirty year old hoses.......gawd what is wrong with people? Tires and brake hoses have dates. Use them.............. |
Unobtanium-inc |
Feb 13 2018, 05:05 PM
Advanced Member Group: Members Posts: 2,199 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
The worst part about brakes hoses, is they can look great on the outside and be almost completely clogged on the inside.
Attached thumbnail(s) |
Justinp71 |
Feb 13 2018, 05:22 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
While your in there give your front tire a good "shake" verifying the front end is tight. Something the "shake" wont show though- I recently discovered the PO had installed early style 911 struts on the factory later style ball joints. It physically fits and was tight, but not meant to go together and potentially dangerous. |
Lo-Fi Version | Time is now: 25th April 2024 - 10:37 PM |
