Do Boxster calipers fit factory 16" Fuchs wheels, Some help please |
burton73 |
Feb 14 2018, 09:58 AM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Do the Boxster calipers fit factory Fuchs wheels. And do they need to be 16 in wheels.
I am putting Boxster Calipers on my V8 car and I want to know that the 16 Fuchs factory wheels in 16 inches will fit with 7 inch (911) and 8 inch( 951) wheels, Or 8 in (911) Thanks as always for the help. Bob B (IMG:style_emoticons/default/pray.gif) |
Justinp71 |
Feb 14 2018, 11:07 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
For anyone running 15" wheels you can go with Wilwood Calipers... Also there are a couple tricks to installing these, I can inform anyone interested.
Attached thumbnail(s) |
andys |
Feb 14 2018, 12:19 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
For anyone running 15" wheels you can go with Wilwood Calipers... Also there are a couple tricks to installing these, I can inform anyone interested. I'm interested in the tricks to install. Which Wilwoods? Piston sizes? What calipers are you running on the rear? Master cylinder diameter? Thanks, Andys |
burton73 |
Feb 14 2018, 03:39 PM
For anyone running 15" wheels you can go with Wilwood Calipers... Also there are a couple tricks to installing these, I can inform anyone interested. I'm interested in the tricks to install. Which Wilwoods? Piston sizes? What calipers are you running on the rear? Master cylinder diameter? Thanks, Andys What are you going to do for emergency brake? Bob B |
Justinp71 |
Feb 14 2018, 03:45 PM
For anyone running 15" wheels you can go with Wilwood Calipers... Also there are a couple tricks to installing these, I can inform anyone interested. I'm interested in the tricks to install. Which Wilwoods? Piston sizes? What calipers are you running on the rear? Master cylinder diameter? Thanks, Andys What are you going to do for emergency brake? Bob B The PO install a 911 drum style emergency brake. I'm only replacing the front calipers with wilwood. |
Lo-Fi Version | Time is now: 6th May 2024 - 08:12 AM |
