A.I.R Pump tube, elimination |
JOEPROPER |
Feb 14 2018, 01:35 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
So, I'm getting my '75 2.0L back together and want to eliminate the A.I.R system. What are guys doing to eliminate the tubes in the cylinder heads? Install and cap them off or install something to block off the passage in place of the tube?
jcd914 |
Feb 14 2018, 01:45 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Easiest way is just to leave them in (or reinstall) and cap them.
You can plug the holes but it requires 10x1.0 bolts that are just the right length. Jim |
bdstone914 |
Feb 14 2018, 03:21 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Easiest way is just to leave them in (or reinstall) and cap them. You can plug the holes but it requires 10x1.0 bolts that are just the right length. Jim I do not agree with leaving them in and capping them. When the smog antlers are not there holding the tubes they can back off. Had this happen more than once. The long tube on a shaking engine will loosen the threads. remove them and plug them. I think a 1/8 NPT tap works. Use red Loctite. Stock is a 10mm fine thread. Had a friend who blew out a tube and walked to the Home Depot to get a bolt to plug it. Bruce |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:05 PM |
