A.I.R Pump tube, elimination |
JOEPROPER |
Feb 14 2018, 01:35 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
So, I'm getting my '75 2.0L back together and want to eliminate the A.I.R system. What are guys doing to eliminate the tubes in the cylinder heads? Install and cap them off or install something to block off the passage in place of the tube?
JOEPROPER |
Feb 20 2018, 05:03 PM
I drilled and installed a Helicoil in the port. Was not as bad as thought it would be. Opened the hole a bit to fit the tap and the insert, red loctite and done. Now waiting for the PMB delivery so I can install the plugs described above.
Thanks for all the help! |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:18 PM |
