Stud specs help... |
MikeM |
Feb 15 2018, 11:23 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
I have a 73 2.0 liter that has been converted to carbs. I'm using a phenolic spacer under the intake manifolds to stop heat from cooking the carbs. Problem is that the studs that attach the intake to the heads are now too short and the nut only holds by a thread or 2. Does any know what I can use for a longer stud? Or maybe someone knows the specs of the stud? Is this a good idea? Will the old studs come out of the head? Thanks, Mike |
Mueller |
Feb 15 2018, 11:44 AM
8 x 1.25, I think 40mm long Yes they can be removed using the double nut trick. Most auto shops will have longer ones or you can order them from Amazon |
rhodyguy |
Feb 15 2018, 01:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are you using tall or short intakes? The Belleville/schnor (sp) washers, used on cv bolts, are a good option if you are using cut steel lockwashers. The B/S ones buy you a little room and you don't need a bunch of torque to get them to work.
sithot |
Feb 15 2018, 01:48 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Are you using tall or short intakes? The Belleville/schnor (sp) washers, used on cv bolts, are a good option if you are using cut steel lockwashers. The B/S ones buy you a little room and you don't need a bunch of torque to get them to work. Studs: https://www.mcmaster.com/#threaded-rods/=1bl1594 Snap on and others make a tool for removing studs which is easier than a double nut. Stud Remover, M8 x 1.25 TPI https://store.snapon.com/Stud-Remover-Sets-...PI-P884757.aspx https://store.snapon.com/Stud-Remover-Sets-...PI-P884757.aspx https://www.lowes.com/pd/KD-Tools-8-Piece-M...AyABEgJAzvD_BwE Lowes: KD Tools 8-Piece Metric/SAE Stud Removal Kit Item # 445713 Model # KDT41760 Reasonably sure Harbor or Northern Tool sell these as well. |
type2man |
Feb 15 2018, 01:53 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I wouldnt add the spacers, especially where you live. You want the manifold to heat up quickly in colder climates. Just install the thick paper gaskets. You won't harm anything
98101 |
Feb 15 2018, 02:30 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
Hi all... I have a 73 2.0 liter that has been converted to carbs. I'm using a phenolic spacer under the intake manifolds to stop heat from cooking the carbs. Problem is that the studs that attach the intake to the heads are now too short and the nut only holds by a thread or 2. Does any know what I can use for a longer stud? Or maybe someone knows the specs of the stud? Is this a good idea? Will the old studs come out of the head? Thanks, Mike Same problem on mine... a couple of the nuts don't reach the nylock as the previous owner set it up. Two mechanics looked and weren't too concerned about it.... but kinda bugs me. |
rhodyguy |
Feb 15 2018, 02:32 PM
CB tall manifolds have thinner bases than the 'shorties' I've come across.
MikeM |
Feb 15 2018, 02:35 PM
I wouldnt add the spacers, especially where you live. You want the manifold to heat up quickly in colder climates. Just install the thick paper gaskets. You won't harm anything When I bought the car there were no spacers. After shutdown the carbs got so hot that the fuel would boil. Added the spacers and problem solved. |
MikeM |
Feb 15 2018, 02:50 PM
rhodyguy |
Feb 15 2018, 03:04 PM
around 1/4". that's buying you some room and might allow retaining the phenolics. what are you using for washers?
MikeM |
Feb 15 2018, 03:15 PM
sithot |
Feb 15 2018, 03:35 PM
around 1/4". that's buying you some room and might allow retaining the phenolics. what are you using for washers? I'm not using any washers!! No room!! You need a thin washer. 8mm that will fit under the nut. PVT nuts are good if you're scared of vibration but I've never had an issue with a nylon lock nut. I use these on velocity stacks for extra "grip". https://www.belmetric.com/stainless-high-type-c-3_752_1481/ |
MikeM |
Feb 15 2018, 03:44 PM
around 1/4". that's buying you some room and might allow retaining the phenolics. what are you using for washers? I'm not using any washers!! No room!! You need a thin washer. 8mm that will fit under the nut. PVT nuts are good if you're scared of vibration but I've never had an issue with a nylon lock nut. I use these on velocity stacks for extra "grip". https://www.belmetric.com/stainless-high-type-c-3_752_1481/ I'm using the nylon nuts and they don't vibrate loose. |
rhodyguy |
Feb 15 2018, 04:49 PM
That thin washer is the one for the cv bolts. Standard metric nut.
Lo-Fi Version | Time is now: 6th May 2024 - 08:57 PM |
