Stud specs help... |
MikeM |
Feb 15 2018, 11:23 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
I have a 73 2.0 liter that has been converted to carbs. I'm using a phenolic spacer under the intake manifolds to stop heat from cooking the carbs. Problem is that the studs that attach the intake to the heads are now too short and the nut only holds by a thread or 2. Does any know what I can use for a longer stud? Or maybe someone knows the specs of the stud? Is this a good idea? Will the old studs come out of the head? Thanks, Mike |
rhodyguy |
Feb 15 2018, 01:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are you using tall or short intakes? The Belleville/schnor (sp) washers, used on cv bolts, are a good option if you are using cut steel lockwashers. The B/S ones buy you a little room and you don't need a bunch of torque to get them to work.
sithot |
Feb 15 2018, 01:48 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Are you using tall or short intakes? The Belleville/schnor (sp) washers, used on cv bolts, are a good option if you are using cut steel lockwashers. The B/S ones buy you a little room and you don't need a bunch of torque to get them to work. Studs: https://www.mcmaster.com/#threaded-rods/=1bl1594 Snap on and others make a tool for removing studs which is easier than a double nut. Stud Remover, M8 x 1.25 TPI https://store.snapon.com/Stud-Remover-Sets-...PI-P884757.aspx https://store.snapon.com/Stud-Remover-Sets-...PI-P884757.aspx https://www.lowes.com/pd/KD-Tools-8-Piece-M...AyABEgJAzvD_BwE Lowes: KD Tools 8-Piece Metric/SAE Stud Removal Kit Item # 445713 Model # KDT41760 Reasonably sure Harbor or Northern Tool sell these as well. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:32 AM |
