IDF Velocity Stacks, Found! |
Mblizzard |
Feb 15 2018, 01:00 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Looking for 4 IDF velocity stacks. Not sure I need them with my TBI system but thought I would see if there were some out there for a reasonable price.
Dominic |
Feb 15 2018, 02:47 PM
Dominic Group: Members Posts: 991 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
What size are you looking for? 40mm or 44mm?
rhodyguy |
Feb 15 2018, 03:06 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mike, are those pictured yours?
Mblizzard |
Feb 15 2018, 05:24 PM
rhodyguy |
Feb 15 2018, 05:34 PM
Are going to use the old cross bar linkage on your new setup? (IMG:style_emoticons/default/blink.gif)
euro911 |
Feb 15 2018, 07:06 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
CB Performance is the place to get them.
Mblizzard |
Feb 15 2018, 07:19 PM
Are going to use the old cross bar linkage on your new setup? (IMG:style_emoticons/default/blink.gif) Nope already ordered the CB bell crank linkage! |
Mblizzard |
Feb 15 2018, 08:03 PM
euro911 |
Feb 15 2018, 10:15 PM
CB again for the stacks - that's where I got mine ...
http://www.cbperformance.com/searchresults...w=15&page=1 |
Tbrown4x4 |
Feb 16 2018, 03:10 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Sorry for the hijack, but what kind of TB's are those?
Mblizzard |
Feb 16 2018, 08:25 AM
Mblizzard |
Feb 16 2018, 10:00 AM
CB again for the stacks - that's where I got mine ... http://www.cbperformance.com/searchresults...w=15&page=1 Found for $27 at CB. Hard to beat! |
JamesM |
Feb 16 2018, 01:02 PM
Senior Member Group: Members Posts: 1,890 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
mike, are those pictured yours? Yes. Have to verify size. But because they are only throttle bodies I am not sure if the stacks are even needed? Not mandatory but in theory should improve flow and differing lengths can be used tune the intake length to take advantage of intake resonance. Are you putting these on your 2056? 48mm ITBs are HUGE for that size motor, may run into some throttle modulation issues at lower RPM. Hit me up if you need some pointers on tuning ITB mode in Megasquirt. I just tuned a 2270 with ITBs last summer, lots of fun. |
Mblizzard |
Feb 16 2018, 02:05 PM
mike, are those pictured yours? Yes. Have to verify size. But because they are only throttle bodies I am not sure if the stacks are even needed? Not mandatory but in theory should improve flow and differing lengths can be used tune the intake length to take advantage of intake resonance. Are you putting these on your 2056? 48mm ITBs are HUGE for that size motor, may run into some throttle modulation issues at lower RPM. Hit me up if you need some pointers on tuning ITB mode in Megasquirt. I just tuned a 2270 with ITBs last summer, lots of fun. Going on 2270 as well. Can’t leave well enough alone! |
Lo-Fi Version | Time is now: 27th April 2024 - 08:26 AM |
