IDF Velocity Stacks, Found! |
Mblizzard |
Feb 15 2018, 01:00 PM
Looking for 4 IDF velocity stacks. Not sure I need them with my TBI system but thought I would see if there were some out there for a reasonable price.
rhodyguy |
Feb 15 2018, 03:06 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mike, are those pictured yours?
Mblizzard |
Feb 15 2018, 05:24 PM
JamesM |
Feb 16 2018, 01:02 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
mike, are those pictured yours? Yes. Have to verify size. But because they are only throttle bodies I am not sure if the stacks are even needed? Not mandatory but in theory should improve flow and differing lengths can be used tune the intake length to take advantage of intake resonance. Are you putting these on your 2056? 48mm ITBs are HUGE for that size motor, may run into some throttle modulation issues at lower RPM. Hit me up if you need some pointers on tuning ITB mode in Megasquirt. I just tuned a 2270 with ITBs last summer, lots of fun. |
Mblizzard |
Feb 16 2018, 02:05 PM
mike, are those pictured yours? Yes. Have to verify size. But because they are only throttle bodies I am not sure if the stacks are even needed? Not mandatory but in theory should improve flow and differing lengths can be used tune the intake length to take advantage of intake resonance. Are you putting these on your 2056? 48mm ITBs are HUGE for that size motor, may run into some throttle modulation issues at lower RPM. Hit me up if you need some pointers on tuning ITB mode in Megasquirt. I just tuned a 2270 with ITBs last summer, lots of fun. Going on 2270 as well. Can’t leave well enough alone! |
Lo-Fi Version | Time is now: 11th May 2024 - 05:48 AM |
