Need help removing top targa pad, Won't budge |
914 RZ-1 |
Feb 15 2018, 07:16 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I need to remove the rear window and to do that I need to remove the top rear targa pad and the side pads by the seat belts. I've removed all the screws but the top pad will not budge. What am I missing?
There don't appear to be any screws in the bottom set of holes and I was able to unscrew the screws in the front of the pad. |
Bartlett 914 |
Feb 16 2018, 08:18 AM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have had it where I remove the screws only to find that there were 2 screws there. I assume one gets pushed aside and the installer just puts in another screw. Use a light and make sure the screw you thought was removed actually was.
I need to remove the rear window and to do that I need to remove the top rear targa pad and the side pads by the seat belts. I've removed all the screws but the top pad will not budge. What am I missing? There don't appear to be any screws in the bottom set of holes and I was able to unscrew the screws in the front of the pad. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:27 AM |
