Reconditioning Seat Belts, Do we have anyone doing this? |
aharder |
Feb 15 2018, 08:13 PM
Advanced Member Group: Members Posts: 4,386 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Do we have anyone here that can recondition seat belts? My Drivers belts is getting pretty weak and I'm not sure I want to dig into that task
Chris914n6 |
Feb 16 2018, 01:29 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It's usually dirt/sweat buildup on the belt. The retraction mechanism is just a coil spring and a gravity lever to lock it on hard stops.
Easiest DIY would be to pull it out, scrub it with a tooth brush and diluted dish soap, rinse it and let it dry. Then it should be back to normal. |
marksteinhilber |
Feb 16 2018, 02:24 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
It's usually dirt/sweat buildup on the belt. The retraction mechanism is just a coil spring and a gravity lever to lock it on hard stops. Easiest DIY would be to pull it out, scrub it with a tooth brush and diluted dish soap, rinse it and let it dry. Then it should be back to normal. Agreed, I've removed my webbing and cleaned it with soap and water soaking. You pull the webbing out to full extension and it is simply looped over itself after passing through a slot in the winder. My spring retract seemed weak though, so I wound up more spring tension before re-installing the webbing into the slot. Rust on the chrome guides also causes slow retraction, so cleaning and polishing there helps. I would worry about UV deterioration of the webbing as the safety issue.... |
Lo-Fi Version | Time is now: 11th May 2024 - 07:44 AM |
