Oil/strainer |
Oil/strainer |
Chip |
Feb 16 2018, 07:52 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Changing oil after car has sat for 30 yrs. I have some APCO synthetic graphite 10-40 oil. Should I use it in the crankcase?
Also, two hoses are coming from the oil strainer cap. Not sure where they go. (Up). Nut is stripped on strainer. Can I remove hoses? they appear to be vents for emission control. |
Feb 16 2018, 11:17 PM
Graphite? No, not something you want in your engine generally speaking.
What are you calling the strainer? If it's on the bottom of the engine, the nut being stripped is a super bad thing. Possibly "replace the crankcase" bad, if things are bad enough. --DD |
Krieger |
Feb 17 2018, 12:09 AM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Take a picture of the strainer and post it here.
Lo-Fi Version | Time is now: 4th May 2024 - 05:36 AM |
