Whats this wire/connection do?, Restoring PO mess |
simonjb |
Feb 17 2018, 12:59 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Hi,
So I have now spent about 20 plus hours fully restoring all the wiring connections that the PO had messed with over the years under the dash. As others have said, once you understand the wiring diagram, its not that bad. But I have one remaining wire thats been cut. I traced it from near the fuse box to a connector on the steering wheel column. Its red (the larger of the red wires) and connects to the pin that I have indicated with the my gauge. Any idea whats this for? |
JeffBowlsby |
Feb 17 2018, 02:19 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
headlight switch
simonjb |
Feb 17 2018, 03:45 PM
Thanks Jeff - Thats the one that was the worst.
rgalla9146 |
Feb 18 2018, 08:09 AM
Advanced Member Group: Members Posts: 4,547 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
majkos1 |
Feb 18 2018, 08:21 AM
Member Group: Members Posts: 215 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
rgalla9146 |
Feb 18 2018, 08:49 AM
Fake news ? |
gms |
Feb 18 2018, 08:57 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I am going to say ignition switch
large gauge wires and the yellows goes to the starter |
gms |
Feb 18 2018, 09:00 AM
I looked up ignition switch and this fits the bill
rgalla9146 |
Feb 18 2018, 09:25 AM
JeffBowlsby |
Feb 18 2018, 09:28 AM
Gentlemen, In answer to the OP's question the schematic indicates that circuit connects from the ignition switch (the 6 sided housing shown) to the headlight switch.
gms |
Feb 18 2018, 09:42 AM
sixnotfour |
Feb 18 2018, 09:50 AM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
you are all correct (IMG:style_emoticons/default/threesome.gif)
rgalla9146 |
Feb 18 2018, 09:57 AM
Gentlemen, In answer to the OP's question the schematic indicates that circuit connects from the ignition switch (the 6 sided housing shown) to the headlight switch. I see...my bad Glenn...not your bad.....my bad. Jeff read the question. Great call. I looked at the picture. Rory Can I be a 1/2 right ? |
JeffBowlsby |
Feb 18 2018, 10:05 AM
:group hug: (IMG:style_emoticons/default/wink.gif)
Feb 18 2018, 11:49 AM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can I be a 1/2 right ? You didn't lose, you were just the last of the winners! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 04:44 PM |
