Lift |
Lift |
Cracker |
Feb 18 2018, 09:39 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Thoughts, experiences, frequency of use, etc. If you have pictures of your set-up in general; decisions you wish you had made; decisions you were thankful you DID make - all would be helpful! I have plenty of ceiling height; do I need to spend big bucks for infrequent use (mostly as a storage device)? The lift will need to be functional for teener engine drops...suffice to say, it has to be a two-post.
Tony |
Bartlett 914 |
Feb 18 2018, 12:48 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
You can do more using a 2 post. 4 post is better for storing a car. How would you do a brake job using a 4 post and all wheels are under load? I made the mistake of getting a lift with cables and a hose on the floor (it has a cover / ramp). This gets in the way a lot more than I like. Think moving a transmission jack from front to rear.
bulitt |
Feb 19 2018, 04:20 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
You can do more using a 2 post. 4 post is better for storing a car. How would you do a brake job using a 4 post and all wheels are under load? I made the mistake of getting a lift with cables and a hose on the floor (it has a cover / ramp). This gets in the way a lot more than I like. Think moving a transmission jack from front to rear. Simple. you raise the car on the 4 post slide two heavy 2"x2"x7' steel square tubes under the car frame with wooden blocking under both ends of the tubes. Lower the 4 post your car is suspended in the air. I agree that a 2 post is more convenient if dropping an engine frequently. Or working on suspension/brake bits. But dropping an engine can be done with a 4 post if you are careful and safe. I have learned the uses of my 4 post are only limited by my imagination... Back my pick-up bed under it to unload a motor. Split a Tractor to change out the torque tube. Work on other stuff- tractors, zero turns, etc. Store all sort of stuff on it- lawnmowers, welder, boxes of parts etc... Changing an engine...I put some jackstands under the car before getting underneath it... |
Cracker |
Feb 19 2018, 09:17 AM
LOL! Yikes! How did you attach the drops to the 4x4 posts? Thanks and a thumbs up for creativity! (IMG:style_emoticons/default/smilie_pokal.gif)
Tony |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:13 PM |
